Question about Dell 944 All-In-One InkJet Printer
Reset ink levels on dell 944
I've replaced ink cartridges on my dell 944 printer, print quality is not good, even after running several test/alignment pages, also i can't reset the ink levels, it still thinks its empty.
  • Anonymous Mar 30, 2014
    reset black ink level
  • 53 Answers
If you refilled the cartridges, you may want to try new Dell branded cartridges.
Posted on May 27, 2009
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
Lexmark X4650 InkJet Printer black prints fuzzy. Color is fine, but the black appears out of focus.
Try to check and make sure your black ink level is still good and not about to go empty. On the printer operator panel, press the Setup button > Maintenance > Ink Levels.
If the black ink level is still good, make sure the cartridges are aligned. Try this approach. On the printer operator panel, press the Setup button > Maintenance > Align Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them as well as align the cartridges.
Try to print a document again to verify that the print quality has improved.
Oct 11, 2011 | Lexmark X4650 InkJet Printer
Hi, i'm getting error message 1203 on the printer and we've lost the user's manual. Can you tell me what this is?
Error 1203 is a very interesting error code. Here is what I found out about error 1203
Error 1203 is a very interesting cartridge error. It means your cartridges overflow even from brand new cartridges after a several prints or right after you refilled the cartridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
I use the lint free cloth(coffee filter work great) with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
Then before you print anything, you should run aligned the cartridges a couple times then run clean cartridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of lint free cloth(coffee filter work great on those holder contact panel.
Article on refilling Dell ink cartridges
Rick
Sep 10, 2011 | Dell 926 All-In-One InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
Reset the ink memory level after replacing cartridge
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
Apr 30, 2009 | Dell 962 Photo All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 944 All-In-One InkJet Printer Logo
456 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
