Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Machine wont work and flashes f12 on function display
Machine flashes f12 on function display no other activity does anyone know how to fix an f 12 display error on a hotpoint w630 washing machine pls? pls email: recruitment@mediabrandsww.com thanks so much! r
    Problem Solver:
  • 8 Answers
F12 is classed as a communiction error.
Either faulty connections or electronic panel
Posted on May 28, 2009
How to unlock the child lock on the AEG L98690FL washing machine. Thanks
5.18 Child lock function
This function prevents children operating the control panel.
• To activate this function, touch button 12 and button 11 at the same
time until the display shows the symbol .
• To deactivate this function, touch button 12 and button 11 at the
same time until the symbol goes off.
You can activate the function:
• Before you touch the button 6 : the appliance cannot start.
• After you touch the button 6 , all the buttons and the programme
knob are deactivated.
untitled-rq2y3fnvghvfrpvxa33jafnd-5-0.jpg Display:
untitled1-rq2y3fnvghvfrpvxa33jafnd-5-6.png Dado
Apr 19, 2017 | AEG Washing Machines
My machine starts and then flashes F12 and stops working what's wrong please?
Deborah,
if your machine is a Hotpoint/Indesit the F-12 error code is a communication error between the main pcb and the display pcb. No simple fix im afraid, a new main pcb is required.
you will need to contact the manufacturer.
Aug 19, 2016 | Whirlpool Washing Machines
F-08 indicated.
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Jan 29, 2016 | Hotpoint Washing Machines
How to open baklit or activate the light
If you're talking about the backlight inside the lcd screen, it would be easier to just replace the lcd screen. Take my word for it.
And how do you know it's the backlight instead of the lcd inverter? Is the screen dark? If so try this:
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 14, 2012 | Computers & Internet
What's your problem?Need help to fix my kurzweil pc 88 ... no function just powers on but no display...need help urgent
Apr 01, 2012 | Computers & Internet
My hotpoint wf840 is displaying f-12 and wont start. Whats wrong with it?
  • F12 - Communication error
  • A thing to do is reset machine to do this unplug for 5 mins and plug it back in if still does it then check the wires into the pcb board to see if wires have come loose or water is on it hope this helps
Jan 06, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing machine WT960 is flashing F-12
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODESAccording to hotpoint website
Nov 26, 2011 | Hotpoint Washing Machines
My washer is flashing F-12 what does this mean?
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PCB, just needing re-seating- by an engineer ;-0(
John C
Mar 21, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine has error code f-12
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
If this helps please rate me
Sep 10, 2010 | Hotpoint Washing Machines
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
1,043 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
