Question about HP Photosmart C3180 All-In-One InkJet Printer
Print isn't clear. Can I align the heads ?
This is an HP3180 all in one and when I print the color doesn't stack properly so it looks like almost double or a shadow.
    Scholar:
  • 89 Answers
Hello
If you follow the instructions in this link it should correct your "Ghosting" problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00662882&lc=en&dlc=en&cc=us&lang=en&rule=15251&product=1146331
Posted on May 27, 2009
Why won't my machine print in color
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 21, 2013 | Epson WorkForce 500 All-in-One Color...
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Will not proceed with reallignment--says to insert paper and press ok but then it doesn't do it.
This device having auto alignment Technic,If print heads are clogged it will not print align page properly result alignment will not completed. In this condition it will ask for align print heads when ever printer switched on. To over come from this situation clean print heads fist, manually or though tool box, then try for align. If printer heads are out of health condition replace faulty print heads then perform align process.
Oct 27, 2011 | HP Photosmart 3210 Printer
My Hp C5280 photosmart printer keeps failing to properly print the alignment page, I just now change the black, is it possible that since my color is out that it will not print properly?
Yes this can happen.
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Aug 20, 2011 | HP Photosmart C5280 InkJet Printer
Epson stylus photo r300 removed print head, flushed out all nozzels with water, dried everything, reasembled everything, including the flat ribbons, two different times. After dozens of times trying to...
If an inkjet printer has not been used for some time and several print head cleaning has been done and it still does not print properly then the nozzles in the print head are blocked.
Inkjet printers need to be used frequently to prevent nozzles blocking with dried ink.
You need to replace the print head to get the printer functioning again.
But these print heads are expensive to replace, it may be better to buy a better and a later model printer for not much more costs.
Feb 24, 2011 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus CX4800 prints blurred pictures
ok..first you will need to print the nozzle check and see if all the color are printed out fine.. this feature is under the printer properties , under the utility tab.... assuming all your colors nozzle are printed fine..then the next thing for you to do is do the Print Head Alignment.. it's under the same place where you print the nozzle check.. when you press the Print Head Alignment, it will print a page out with many lines.. choose the one with the best alignment.. once u done that..try printing the image again..
oh..if your nozzle check print out is not good.. then you will need to perform head cleaning to clear the clogged head..
May 24, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
My HP C6150 prints pictures fine but the text is incomplete. I have tried different ink cartridges and have cleaned print head and done a cartridge alignment. What else is there?
1. During the cleaning of the print heads you probably clog some of the jets that distribute the ink.
If you didn't use the proper cleaning procedure you may have damaged the print heads.
the color heads are probably not affected therefore the pictures prints come out clear.
Mar 23, 2010 | HP Photosmart C6100 All-In-One Printer
HP C7280 does not print straight, ie the print is angled on page
There is no way that a printer prints out of alignment unless the paper slips enroute. Meaning that the rollers are not holding the paper tight and the guides not pressing the paper snugly, as you put it. So, it could either be the rollers not aligned to each other properly or the guides not pressing the paper equally. The print head moves on a steel rod which is straight. So that can not be the culprit as the print head has to move in a straight line, irrespective of the paper being straight or slipped. So, that leaves us with the slipping paper for which there are the rollers and the guides. If you feel that the tension in the guides is not equal, then change the guides, else the rollers need a closer look. Or at least clean them with a damp soft cloth and allow them to dry up before using them.
Nov 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
