Question about Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
Which way does the final filter for the hoover u6430-900 go back?
I was cleaning the 2 washable filters on my windtunnel u6430-900 and forgot how the multi layered/multicolored final filter goes back in. The manual just says replace in reverse order. One side is white, the other side is turquoise. Someone please tell me which color is against the bodyof th emachine/which color is visible through the slats in th efilter cover. Thank for your prompt reply!
  • Hoover Master
  • 1,545 Answers
It doesn't matter which way it goes but I recommend replacing it rather than cleaning it.
Posted on Sep 08, 2017
5 Suggested Answers
skyblue67
  • 71 Answers
SOURCE: Final Filter-Hoover U5399-900 WindTunnel Lite Upright Vacuum
Hi you could try these people who deal with hoover parts their number is 0845 230 6 230
they are called www.espares.co.uk
hope this helps if they dont have your part they should be able to get one or direct you to another supplier.
Posted on Jul 19, 2009
Vac Belts
  • 701 Answers
SOURCE: Hoover U6634-900 WindTunnel
You need to replace it periodically. Below I have listed a link to the belt you need and a link to the manual which has instructions.
Hoover U6634900 Replacement Belts
U6634900 Manual
Posted on Nov 03, 2009
ftw1952
  • 10319 Answers
SOURCE: Hoover self-propelled windtunnel U6430-900 flat
Belts get hot when fibers from carpet get wound arounf the belts mounting shaft. Best to take a razor and cut off any fibers so the belt doesn't get hot again
Posted on Aug 10, 2010
  • 240 Answers
SOURCE: Hoover Ultra U6430-900 WindTunnel Bagged
The wider belt is # 38528035,( package # 40201170 ), and the v-belt is # 38528034, ( package # 40201200 ). The wide belt should be replaced twice as often as the v-belt.
Posted on Jul 06, 2011
Vacuum not clogged but has low suction
Check all the pipes, there could be something stuck in them which hasn't come out.
Also check the base of the vacuum if there is something stuck in the base.
Lastly check if there are any leaks in the pipes.
Also check the suction without using the handle, by pulling the pipe in your hand and see if it has more suction.
Apr 28, 2014 | Hoover U6630-900 WindTunnel Bagless...
Windtunnel quits picking up
clean or replace the main filter. this filter is non washable. the best way to clean is to use a paint brush or compressed air. hope this helps
Jul 25, 2009 | Hoover U8147-900 WindTunnel V2 Bagless...
I have a eureka boss capture bagless
by the pic, its not an eureka, its a hoover w.t. s.p . if you removed the clog and still nothing, change the bag or clean the washable filter at the bottom of the bag.(belts should be changed every 6 months)
Jul 20, 2009 | Hoover U6446-900 WindTunnel Bagged Upright...
My Hoover Windtunnel cuts off after using it for a few minutes. After an hour or so, I can turn it back on again. This keeps happening every time I use it. This is my third one. I have taken the other two...
yes this machine has a thermal protector in it to shut off the machine if it gets to hot, this is normal. if there is no clogs in the hoses or in the machine then you will need to wash the filter at the top of the machine. you will have to remove the dirt cup and at the top you should see a half moon orange, well inside of this piece is the washable filter, clean and let it dry completly before putting back into machine. if this gets dirty and has not been cleaned, you can lose alot of suction. in some cases if this filter is not cleaned it can cause the machine to overheat so bad that it can damage the motor.
May 30, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
May 18, 2009 | Hoover U5399-900 WindTunnel Lite Upright...
Burning smell coming from vacuum
use a penny to turn the 2 screws on top a quater turn then fold down the vacuum and lift up the cover and you will have access to the belt. Clean the small hepa filter with soapy water. their may be 2 of them. The cannnister filters need to be shaken but not washed. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel shuts off
I found the following solution on this website. I have searched for hours and finally found this solution, it works! I HAD the same problem after cleaning the filter mentioned below, it is now working like it was new.
***by maverick_bea***
Jul 27, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Wind Tunnel 2
The filter for the U5753 does not rotate on it's own. There is a knob on the lid of the dirt canister to rotate before you empty the container, but it does not rotate automatically. If the filter is getting dirty quickly, it could be a result of very fine dirt going through the pre-filter screen and blocking the filter. You should also check the filter UNDER the dirt container for blockage and also the exhaust filter on the side. These are both washable and must be bone dry before re-installing
The main filter cartridge is a long cylindrical style and is coated with a teflon material so that all you should have to do is tap the filter lightly to dislodge any dirt. You can wash the filter by running warm water over it and using a SOFT brush to clean the surface. This filter must be BONE DRY..... before re-installing.
By the way, the lifetime filter is not lifetime. It should be replaced every two years, under normal use.
Aug 30, 2007 | Hoover U5753-900 WindTunnel Bagless...
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum Logo
139 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
