Question about Craftsman Gas Mini - Tiller/Edger
Craftsman Edger 536-797520 is leaking gas from the air filter
My Craftsman Edger/Trimmer 536-797520 is leaking gas from the air filter. I replaced the air filter last year and the edger worked fine. This year the gas is leaking from the filter. myyard.blues25
  • 376 Answers
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
Gas is leaking after I put gas in. It looks like the fuels lines are in. Does the filter attach to the gas lines? I don't see an air filter on my 536-77240000 craftman edger.
If you just replaced the lines, alot of times the lines outerm diameter is not correct, causing leaks...other times its the gas cap itself, However, there shouldn't be any hole under a gas tank... at least not where any air filter would be close by..
Sep 26, 2015 | Garden
What is the red tube inside the airfilter, it constantly leaks a stream of gas
ALL I CAN TELL YOU IS THAT THE TUBE IS DISCONNECTED @ ONE END OR THE TUBE HAS A HOLE ON IT ! "look" @ THE AREA CLOSELY...YOU WILL FIND IT!!!!!
May 23, 2014 | Craftsman Garden
Looking for the part number of the air filter on craftman edger model # 53685648
On the Sears Parts Direct, they show no air filter. I would recommend taking the filter to a small engine shop so they can match it up or just go to Home Depot and match it up with one of their filters they may have in the lawn and garden. Lowes has a small engine section too, most of their stuff is Briggs and Tecumseh. Here is your parts diagram, with no air filter shown.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Edger-Parts/Model-53685648/0247/1503400?sid=PDVertical
Aug 13, 2011 | Craftsman Gas Mini - Tiller/Edger
I have a Craftsman Edger/Trimmer Model # 53677230100. This year I put gas into the tank and it just leaks right out through the carb. out of the attached filter.?.?
You have a malfunctioning float and/or needle valve in your carburetor. Disassembly, cleaning and possible replacement of parts will be required.
Apr 22, 2011 | Craftsman Garden
Where can i buy new gas line(Oregon)? For Sears edger.
its only silicone tube have a look in some model shops for fule line or pet shops that sell "fish!" the tube used in fish tanks to pump air or water through the filters will also work for fule pipe,,so long as its silicone tube it will work fine,, trust me on this i use it all the time
Jul 29, 2010 | Craftsman Convertible 25cc. Gas Line...
Craftsman edger won't start
Does it have a primer bulb? If so, make sure the bulb is not cracked. Also, make sure the fuel lines are not cracked and the fuel supply line reaches the bottom of the tank. Fuel lines, as silly as it sounds, degrade when exposed to gas for long periods of time. If they are cracked it will draw more air than fuel and not allow the engine to run. You can buy replacement fuel line/primer bulb kits for under $10 at practically any hardware store.
May 24, 2009 | Craftsman Gas Mini - Tiller/Edger
Have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
May 04, 2009 | Craftsman Garden
Craftsman Gas Mini - Tiller/Edger Logo
1,969 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
