Question about Texas Instruments TI-83 Plus Calculator
Frozen, 'snowy' screen...HELP!!!
Hi, when I turn on my calculator the screen is all messed up.  It looks like it is 'snowing' and there are faded numbers in the background. (It looks as though it is frozen.)  The only buttons that do anything are the on and off buttons.  Any Ideas? Is there a way to reset this?  I know nothing about these calculators and any suggestions would be greatly appreciated,
The only solution that I can think of that might work would be connecting the Ti to another Ti of similarly close models and use the "sendOS" function on the working one, this should reset the crapped one to a functioning setup.
This does require the special wire they have for connection 2 calculators together... probably can get it on ebay or something if you don't have it already and just borrow a friend calc in class or something...
If you need more help you can reach me at saik0[dot]com or Saik0Shinigami{at}gmail[dot]com
Posted on Jan 30, 2008
When I print the numbers come out faded, I changed the ribbon is there a way to fix this?
Your ribbon is not seated properly. I would look to make sure you have fed it through all of the guides properly. If this is not a snap in cartridge then I would make sure that the ribbon is feeding the right way and is not upside down.
Feb 25, 2015 | Canon Mp25dv Desktop Calculator 8077a006ab
TI89 dim display
Hi This problem can be fixed
Mar 20, 2012 | Texas Instruments TI-89 Calculator
How do i turn on my TI-83 when i already put batteries inside? at first the numbers would fade away but now it dosent want to even turn on.
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Sep 18, 2010 | Texas Instruments TI-83 Plus Calculator
Screen fading numbers not clear
Usually that is a power problem....change the batteries if your running on battery and if not then the transformer inside is going bad...
Sep 03, 2010 | Texas Instruments TI-30XA Calculator
Main Display Screen has faded so I can see numbers but not real good
The outer LCD screen is messed up now. Fixing this means replacing the front LCD screen... Go to a local repair shop..
Hope that'll help you..
Happy Holidays...
**please rate my post**
Dec 16, 2009 | Samsung SYNC SGH-A707 Cellular Phone
The calculators screen is not fulling showing the
If it is too dark
Try reducing the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
If it is too light increase contrast
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Sep 07, 2009 | Texas Instruments TI-83 Plus Calculator
Printed page not clean, faded characters in background of page. Any suggestions? I cleaned the pickup roller.
Have you tried another toner cartridge? And when you say it has faded characters in the background? Does it look like it's reprinting the image kind of? If so, you will need the fuser unit replaced. The fuser is responsible for melting the toner to the paper, when it goes bad it can cause "ghosting" meaning it reprints previous images. A technician would be needed at this point, the part number for the fuser is RM1-1289.
Please let me know if there is anything else you need.
Aug 03, 2009 | HP LaserJet 1320 Printer
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Calculator screen stratified black lines
call the tech support # 972 644 5580, they man was very helpful and they walk you through troubleshooting
Jan 19, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-83 Plus Calculator Logo
452 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
