Question about American Standard 2373.401.002 Enfield Fixture Mounted Bidet Fitting Faucet
Screw stuck on handle
AMERICAN STANDARD HANDLE SCREW STUCK ANDI DONT WANT TO MESS UP THE STRAIGHT EDGE FOR THE SCREW DRIVER
    Novelist:
  • 166 Answers
You mean the seat washer screw of the faucet is stuck? If that is the case, so as not to be redundant, follow the great guide on how to solve this screw-stuck problem in this handy article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Plumbing_Faucets_Faucet_Seat_Washer_Is_Stuck_Unremovable.htm
This should get you going again.
Brad
Posted on Jun 01, 2009
I'm trying to remove the handles from my american standard bathroom faucet. It is from 1992 model 908497. I can't separate the part under the sink from the handle. I have it were I can lift it up about 1...
I think you might need a handle remover tool. It looks like two "L"'s facing each other with a long screw going through the top of the two L's . With a T handle at the top. The two L's go up under the bottom of the faucet handle, and the long screw fits into the screw hole for the faucet handle. A dozen turns or so and the handle pops off the valve stem. Cost about 10-15 dollars at any hardware store. hope this helps.
Nov 27, 2013 | American Standard Plumbing
I am trying to remove handles from my 1960's shower handles. they are leaking and i cannot seem to find were you unscrew them at. i took the front screw out and cannot seem to go any further. they...
The screws ae under the center cap. unlike todays faucets this cap is screwed in. You will see a little edge on the cap so you can take your channel locks and turn it counter clock wise. Under that is the bress screws.
You might need a handel puller if they have not been appart for so many years. The puller will also protect you from breaking the stem and the handle.
Hope this helped you out, we all know how little things kick our butts.
Thanks again
Tom
Sep 09, 2011 | American Standard Hampton Two-Handle...
R120 Valve I have good pressure with the cold water but no pressure with hot water
I imagine you have the installation instructions since you just installed it. Your new shower handle has a hot limit safety stop. You can set this with a flat blade screwdriver. The safety stop is the red ring in the handle and all you need to do is pry the ring forward with the screw driver and rotate it clockwise to increase your hot water.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 12, 2011 | American Standard R120 Pressure-Balance...
My American Standard low water consumption toilet is leaking water. It is not the flapper, as the water level drops below the flapper seat. How do I fix it? I'm not sure of the model, but the tank is...
Did you try calling or emailing the parts dept. at american standard? I am not sure if they just sell the gasket. American standard parts are certainly different from most toilets. I looked on ebay, not much for american standard toilets. Were you able to remove the four screws and get the sealer under the gasket.? I will do some more research for you and try to find parts. take care, andy
Feb 17, 2011 | American Standard Toilet Ravenna 2646.016...
How to adjust the rotation of handle from hot to cold is centered
look for a small cover plate on the back of the handle. Pop it off with a flat screw driver. Inside should be a screw to remove the handle. remove handle and re install to desired location
Jun 09, 2010 | American Standard Kitchen Faucet 6310 020...
How to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Jun 05, 2009 | American Standard 4275.550.002 ColonySoft...
Handle stuck; How descale w/o ruining chrome finish
WD-40 will not harm the chrome but it you have liquid wrench, it would be better lubricant as WD 40 chemicals are actually a cleaner.
A descaler you need to be careful here. Lime-away or CLR is a popular choice but you need to read the label on chome products.
Jan 25, 2009 | American Standard Collection 4241.002...
Mixer taps
you didnt mention which side hot or cold?
it sounds like its scaled up & the o ring has dried out so it could be a case of replacing o ring & regreasing. ifits when you turn either hot or cold & its stiff then a replacement cartridge will required
Kindly
Richie
Aug 29, 2008 | Plumbing
American Standard 2373.401.002 Enfield Fixture Mounted Bidet Fitting Faucet Logo
223 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
