Question about Whirlpool AWM5145/2 Front Load Washer
Rotating programme unit stops mid cycle, all programmes
AWM 51545 1400 front loader washing machine. The programmer sticks mid cycle, when you advance the programmer manually a little it starts to work, But the machine takes in more water and ends up overfilling the drum, leading to water leakaging through the door seal and making a loud noise when the drum is over full.
The water is discharged when you set the programmer onto the drain position.
Please can you help to identify the problem and the replacement part required.
  • Anonymous Mar 19, 2014
    I have a problem, a power cut caused my machine to stop mid cycle. Then the programme would not finish, so I have drained the water from the machines drum and filter. unplugged the machine for 1 hour for the programme to re-set, the machine now lets you choose a programme but will not lock the door and does not start the programme selected. Please help ?
  • 132 Answers
According to that i think the problem come from timer after you fix this problem pleas donot select your program during conncting electrical power thankyou
Posted on Jun 07, 2009
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Stopping mid cycle, not taking softner, doing a
OKAY.....Could be cold water not entering the machine , due to turned off. or faulty valve coil not too expensive to fix...
May 24, 2010 | Washing Machines
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Cycle sticking when reaching drain point. Have cleaned filter & drawer.
you mention sticking I am wondering if it is not adavncing on it programm if this is the case I would inspect the water pump area for either a fault or a blockage as water trapped in the machine could stop the machine for advancing
Jan 17, 2010 | Zanussi ZJ1217 Front Load Washer
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
WASHING CYCLE STOPS AFTER A MINUTE
Can you skip through the programme to drain? Press pause button. then press start to move the lights down to the empty cycle. leave to finish.
If you have already tried this, I can explain how to put machine into engineer test mode, which will then give out a fault code to identify problem.
Apr 04, 2009 | Zanussi FJD1266W Front Load Washer
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi ZWF1430W Front Load Washer
Programms rotate without stop
Check your instructions, and see if there is a reset point or function, if there is not ,then it has a control unit malfunction, and unfortunately, this is not something you can fix yourself.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Washing Machines
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
Whirlpool AWM5145/2 Front Load Washer Logo
417 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
