Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Refrigerator is not cooling as normal.
The fridge started not cooling properly about a week ago. I removed the bottom piece from the front of the fridge and vacuumed lots of dirt from around the radiator like thing. Now the freezer has frost at the back of the inside and certain items are not as frozen. Please help and reply to IHENTERPRISES1@cox.net Refrigerator not cooling properly
  • 544 Answers
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on May 27, 2009
My refrigerator samsung is not cooling normaly please tell me normal temperature ??? I lost papers intrucions thz
First thing to check is the evaporator coil on your fridge. If it has alot of dust and build up on it, it will not cool properly. Take the front grill off the bottom of the fridge and check your coil. If it's really dirty, use a vacuum with a hose on it to clean. You can also use an old paint brush to remove build up.
May 08, 2011 | Samsung Full Option Side-by-Side...
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Jimmmyj is probably on target with the timer.
All frost-free refrigerator-freezers have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. The Defrost timer in all boxes fails eventually from old age. When that happens, the coils frost over until they become pretty much just a solid block of ice. Most timers are located on the front of the machine, behind that removable grille under the door. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer. If the unit does not chill, there is some other problem either with the defrost heater coils, or the thermodisk. Be advised, all that ice may overflow the pan under the unit.
May 25, 2009 | Kenmore Refrigerators
Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Oct 04, 2008 | Kenmore Refrigerators
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
281 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
