Question about Kenmore 63942 Dryer
Snagged Clothing on drum of dryer
I get clothing that snags on the top front of the drum and ends up scorching the clothing. What are the possible problems and how easy is it to fix?
  • Anonymous Mar 17, 2014
    dryer snagging holes in clothing
Why does the dryer make a rubbing sound it drys the clothes is it clogged maybe
with lint on the bottom of the dryer please give me answer to this question .
Thank you
Linda maldonado
Posted on May 28, 2009
My frigidaire dryer snags clothing on the lint screen. How can I stop this?
Hello Vincent Jones, thank you for your inquiry!
From what you have described your clothing is getting snagged on the lint screen inside of your Frigidaire dryer. You may need to replace your lint screen and filter. I would make sure to check for any cracks or damages that could cause your clothes to get snagged. If you do not see any damage you may want to check the inside of the tub using an old towel or pair of hose to assure there is no internal damage. I hope this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Dryers
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
Jun 21, 2014 | Electrolux EIGD55HIW Gas Front Load Dryer...
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Stackable dryer. clothes gettin stuck in dyer causing holes in clothing
well depending on the brand some brands use a felt seal in the rear and front of drum to seal against the door shroud overtime the felt wears down and clothing get snagged in the gap as the drum turns and tears clothing....
Jan 26, 2011 | Washing Machines
Clothes getting stuck
check the top drum slides and tub bearing slide support. it is made of plastic and when it or the slides wear out the drum will drop down enough for clothes to start snagging
http://www.easyapplianceparts.com/ModelFrames.aspx?ModelID=395857&ModelNum=NWXR483EG3WW&mfgModelNum=&ManufactureID=2&Selected=00125553i02&Position=3&mfg=GE&Type=&Mark=3
May 28, 2010 | Hotpoint Ariston NWXR483EGWW Electric...
Black lint on white clothes after wash. have cleaned filter. is a front loader.
Check both the apron, located in front of the drum for lint residue, as well as the drum itself for sharp points (gouges) which may have snagged clothes and collected the lint to the inner side of the drum. Also try running a full cycle with no load to clear any lint which may remain in the outer (non visible) drum.
Mar 05, 2010 | Washing Machines
Clothes get caught between the drum and the front of the inside nonmovable part of the dryer and we are getting snags of the clothing inside and ruining the clothes
there is suppose to be a felt type piece that goes on the drum to full that gap it may have fell off . its a struggle to put on unless the drum is accessible. you can pop the top of the machine off to get better access.
Aug 23, 2009 | GE DBXR463EDWW Electric Dryer
My kenmore washer#26922503 will not drain during the spin cycle and the cloths come out of the washer with a lot of water still in them. can you help me? armandodawdy@hotmail.com
Sounds like there's been an obstruction on the hose to the pump. Sometimes a sock or other small article of clothing can be swept over the top of the inner perforated drum into the outer drum. The outer drum has about a 5/8" hose to deliver the waste water to the pump. Socks, etc can get stuck in the drum, blocking the drain hole to the hose, OR they sometimes can be sucked down into the pump...Check both . If it is in the outer drum you can fish a straightened coat hanger with a small hook bent on the end and try to snag the article of clothing. or if it is in the pump, you'll need to block the hose so the water won't dump out of the drum and remove the lower end of the hose and then use the coat hanger hook to pull the clothing out of the pump...messy and leaky job, but possible to do.. Also check the pump belt, you may have burned it and when it heats up it will stretch and won't drain when it's stretched..
May 08, 2009 | Kenmore Washing Machines
Marked clothes
probably needs a new front drum seal what is the model#?? Dont forget to rate my solution as solved if i answered your question accurately.....Thanks!!
Sep 30, 2007 | Kenmore 63942 Dryer
Snaged clothes
Check the lint trap on the dryer. We had the same problem and it was because we put the lent trap in backwards.
May 01, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore 63942 Dryer Logo
863 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
