When accelerating I have a loss in power and my truck stalls out once I reach 2 rpm. I have replaced the map & throttle position & crank sensor. Ive checks all hose for leaks. Not sure where to turn next I just bought this 2006 Dodge Durango a month ago and can't even enjoy it. it is so upsetting. any ideas or similar issues known for these deranges?
SOURCE: MAP sensor / does a 2006 f150 have one? and if it
Bad MAP sensor....located on your intake manifold....one connector...1 o-ring
SOURCE: '90 3.1 lumina euro idles ok but tries to stall when accelerated.
If the cat is red then it is probably plugged if the motor can't exhale it wont run at high rpm
SOURCE: I have a 2004 dodge ram 1500 and my truck stalls out
There are two other sensors that may be causing problems. One being the crank position sensor and the other being the Oxygen sensors.
For Acceleration related problems,
Click
the link below to troubleshoot this problem: ---
Car loses power while
acceleration?
http://schematicsdiagram.blogspot.com/2011/12/car-loses-power-while-acceleration.html
Loss of acceleration?
http://technoanswers.blogspot.in/2012/02/loss-of-acceleration.html
Acceleration lag problem?
http://repairhelpcenter.blogspot.com/2012/01/acceleration-lag-problem.html
How exactly the Vehicles
Accelerator Cable works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-cable.html
How exactly Vehicles
Accelerator Pump Diaphragm Works?
http://repairhelpcenter.blogspot.com/2011/11/how-exactly-vehicles-accelerator-pump.html
accelerator pedal sensor?
http://technoanswers.blogspot.in/2012/02/2009-chevy-impala-accelerator-pedal.html
stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
Engine accelerates when brake is applied?
http://technoanswers.blogspot.in/2012/02/engine-accelerates-when-brake-is.html
This
will help.
Thanks.
Click
acceleration?
This
will help.
Thanks.
For
acceleration problem, the help links are provided below, click the link below
to go through its procedure: ----
applied?
How exactly the
Vehicles Accelerator Cable works?
How exactly
Vehicles Accelerator Pump Diaphragm Works?
Car loses power while acceleration?
This will help.
Thanks.
