Question about Sony STR-DE635 Receiver
Blows main fuse when power is turned on
Our Sony receiver blew a fuse. We got new fuses to replace the one that was blown, but when we went to turn the receiver back on it blew the fuse like there might be a short. The fuse is located by the transformer. The two 8amp/125v fuses located directly behind the transformer blew. I replaced them, and upon turning the unit back on, they blew again. What could be the issue. Bad conductor maybe?
    President:
  • 1,489 Answers
Shorted power supply/module is most likely problem.
Posted on May 27, 2009
Why is my GE Advantium SCA2001 blowing the main fuse?
Yeah pal, you've not gone deep enough yet. You'll find a power wire bare inside the unit, pull it apart and tape that wire up to stop it from grounding out and blowing the fuse.
Aug 31, 2014 | GE Microwave Ovens
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
#9 20a fuse in the power distribution box is blown, put new one tried to crank and blew it again
If this fuse only blows when you crank the engine then this would tell me the starter is shorting out and blowning the fuse. make sure to check it by replacing the fuse and turning the key on without cranking the engine and if the fuse doesnt blown then crank the engine and if the fuse blows then its the starter, replace the starter and this will take care of the problem.good day and hope this is helpful.
Apr 10, 2011 | 1999 Mercury Cougar
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Fuse blows when I connect to original power source
You have a bad ground check the ground on the radio the black wire.write back if you need further help.
May 09, 2010 | Panasonic CQ-C1101U CD Player
Fuse replaced but blows againwhen remote clicked for CT32SL14
This is a problem with the main poiwer supply. It could be simply a shorted rectifier diode or more complex. Without taking measurements inside the set or at least seeing what the condition is of the board, there is little we can do to help. This unit shoul dbe brought to a service shop with a request for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair. Expect to pay $50 or more for the estimate.
Dan
Aug 20, 2009 | Panasonic Televison & Video
Sony STR-D565 fuse continues to blow
You could have a shorted winding in the power transformer. The diodes in the power supply can be shorted. Filter capacitors can short and send power to ground which will blow the fuse.
Apr 16, 2017 | Sony STR-D565 Receiver
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Stuck protector mode
find out why the fuse blew in the first place.the protector is just PROTECTING the main circuits of the receiver.the receiver turns on just to confirm the power circuit is OK.
have it checked by an electronic engineer.
Apr 16, 2008 | Sony STR-DE597 Receiver
538 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
