I have a GE Zoneliner AC (cooling only) that every so often simply won't come on. The solution to this problem is to leave it unplugged for a couple of hours, then plug it back in and turn it back on... It keeps on trucking like if nothing ever happened! This happens every couple of weeks. How can I can I fix and/or prevent this from happening?
    Sergeant:
  • 296 Answers
Hi
The mother board kicked the unit off.One thing i would try is pushing the contacts for the compressor in with a screw driver while the power is on, and see if the compressor runs. Be careful not to get shocked doing this. If the compressor does not start, or just humms, then either your compressor is out, or the start relay,and/ or capacitor is out.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your wondering how to check out your refrigeration compressor;
Modern Compressors have two operations that have to work together just to run. More items must be considered for them to work and work efficiently in systems. The 2 areas that must work together are electrical and mechanical. Either your compressor is broken inside or the motor and or start components are not working properly.
Electrical
Ohm the compressor terminals to ground and across to each other.
1. If any read anything to ground the compressor is bad. If not go on to the next step.
2.Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals. If you get only 2 readings don’t panic wait 24 hours for the motor to cool off for sure and recheck it. If still no reading then your compressor motor is open. A new compressor or replacement of the appliance is required. If you now get the 3 readings described make a diagram you feel comfortable with as to where the wires go to each component before removing anything, then continue:
3 Assuming the above checks out: Get a new *Start relay *start capacitor if so equipped relay *external overload and *run capacitor if it has one. In other words everything that is external and attached to the wires or terminals on the compressor or wiring per your diagram and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
*May or May NOT have this component:
*Start Relay:
MOST 99.999…% of refrigerators of the household type have a start relay of some kind and they vary in size shape and color. It plugs directly onto the compressor. SOME AC units but not all have one and it is different. These Resemble a box about 2”X2” X 3” with at least 3 terminals on it and these 3 terminals are marked 1, 2, & 5. Each of these will have at least 1 wire on them and there may be other terminals (4 & 6) as well that can be used with several wires on each.
* Start Capacitor
100% of AC and Commercial compressors that use a start relay (and remember some do not have one but those that do…) and only some domestic refrigerators use a Start Capacitor. At least 2 wires going to a black (usually) cylinder which is the start capacitor. Start Capacitors ALWAYS HAVE 2 or more Wires and ALWAYS HAVE TO HAVE A START RELAY.
*External Overload
MOST 99.9% of Household refrigerators, 80%+ of smaller commercial refrigerators, and most 90% of window unit AC’s but almost no central AC compressors Have an external overload. Those that do not have an internal overload. These vary in size and color and description a basic one is round 2 wires and generally black about quarter size USA AND IF USED ALWAYS MOUNTED ON THE COMPRESSOR with the other wires and terminals there.
*Run Capacitor
Some domestic refrigerators (can be a small rectangular box) medium and larger refrigeration and (99.999%... of all) AC central and Window units have a compressor that requires a run capacitor. These type units also have a fan motor that can require a run capacitor. These Capacitors always have at least 2 wires and often 3 or more if the capacitor also is wired to the fan motor.
If a compressor is tight due to linear expansion from heat a tip worth remembering is as something cools it contracts, except for water at freezing. A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours may have expanded parts from heat. About 1/2 the time it is ok after new start components are installed with a start capacitor and relay. The other 1/2 the compressor will be ok for a day or 2 then stop again. A “hard spot” in the movement of the internal parts in the compressor, and stopping on this hard spot it can’t overcome the “tightness”.
If you follow most of these steps above you will arrive at a correct diagnosis well over 90% of the time ( allowing for what is unusual or for misunderstandings)
REGARDS
Posted on May 27, 2009
Ge refrigerator won't cool. compressor doesn't come on
The compressor is gone, only option replacement.
Apr 18, 2012 | Televison & Video
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Refrigerator and freezer are both cool, not cold.
Pull refrigerator away from wall unplug remove lower cover and feel top of compressor. If too hot to keep hand there leave unplugged until start components, compresser windings and condenser fan can be checked. Let me know what you find and I can assist you, Thanks, Sea Breeze
Feb 20, 2010 | GE GSH22JFT Side by Side Refrigerator
I cleaned the mold out of my ac and now it stopped working. The green light on the plug works and the control panel lights up for a second but then goes back off
if it had mold in it you should throw that thing off a cliff rather than breathe it, but it may have just gotten moisture somewhere it didint need to be unplug it and leave it to dry for a day or to then try again if it doesnt work toss it and get another.
Sep 17, 2009 | GE Built-In Room Air Heat Cool Air...
Freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
