Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 washer needs new clutch. In need of install help...
I found out yesterday and by getting under the machine verified that the clutch on my washer needs replaced but I need to be able to replace it myself as I have absolutely no budget to hire a repair tech. I am quite savvy with this type of thing but all I could find to take off the transmission were three larger bolts and it still didn't move... Please send a link or help with how to get to the clutch... Thanks!
  • 4 more comments
  • PrettyInPink
    PrettyInPink May 27, 2009
    Attached are two pictures...one of the inside as far as I have it down and the other of the bottom of the machine... Am I just supposed to pull the basket off of the spindle in the middle of the machine? Thanks again!
  • PrettyInPink
    As far as it being clean - should have seen it when I found it at the dumpster... lol... since I have it pretty much completely apart I've been cleaning everything that I can so it will be good as new! :D
    I did get the shaft out and have the whole motor assembly out but there is a u-shaped metal clip that is holding the clutch on and I can't figure out how to get it off... So close and yet so far, right? See pic...
  • PrettyInPink
    PrettyInPink May 28, 2009
    Actually, disregard last comment. Miracle of miracles - I got the part changed out and the machine back together... seems to be spinning well but I have missed something underneath that is messing with the balance... back to troubleshooting!
  • PrettyInPink
    PrettyInPink May 29, 2009
    Hmmm... I didn't see anything on the top that had a spring... When it started spinning it was fine for a few minutes and then the whole basket part starting wobbling around like a tire out of balance. And that was with me holding onto the cabinet to make sure it wasn't just a leg out of balance...
  • Samuel Charles Spriggs May 11, 2010
    First of all, that's a really clean machine!!
    The shaft you see in picture 1 in the middle of the transmission is the other end of the shaft sticking up in picture 2.
    Far as I remember (and I have done this specific job on this machine) the transmission just pulls straight out brnging the shaft with it.
    If all obvious bolts are loose, tap lightly on the top of the agitator shaft with a rubber hammer and see if you get any movement.
    My guess is the drive/spline shaft for the agitator is connected to the transmission. Remove the agitator, then lay the washer on it's back or side and pull the transmission and agitator shaft out in one piece.
    Have you tried that already?
    Let me know one way or other.
    thanks...
    Charlie
    President:
  • 1,489 Answers
Is it out of balance when it spins? If so, it could be the damper at the top of the cabinet. I believe on that unit, there is a v-shaped spring rod with a rubber cup which presses on the top back right edge of the tub and keeps it from wobbling.
Posted on May 28, 2009
  • Samuel Charles Spriggs May 29, 2009
    Have you run this washer before without the wobble?
    There should be a damper under the lid.
    If you've never run it, maybe the damper was never there.
    Do you see a spot on the back right where a rubber cup may have sat?
    Note: It doesn't look like a spring -- it's a v-shaped rod...
    Scholar:
  • 85 Answers
You will have to take the agitator out by removing the 7/16 bolt inside it. It is attached to the top of transmission. The it should come out.
Posted on May 27, 2009
I have a Kenmore 80 that doesn't spin
You may not have given me enough information, but here goes. If the washer drain some water and then does not spin, the washing machine clutch assembly needs to be replaced. If it is not draining at all then the water pumps needs to be replaced. Water pump replacement is easy, but the clutch assembly- you better be very experienced. Unplug the appliance before you attempt these repairs! You will need the model number to get the proper replacement parts.
Jan 16, 2010 | Kenmore Washing Machines
Need to know procedure to clean Kenmore Series 80 filter
unbolt the agitator filters should be underneath let me know how you went
Nov 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore Series 70 won't spin
Sounds more like a transmission or a spin tube problem
Jul 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 washer that spins but clothes are still too wet...
to me this sounds like a clutch,
or possibly worse, your transmission that is spitting oil onto your clutch
lift the front of the washer and check to see if there is a puddle of oil on the ground. if so, its most likely your transmission. and a clutch would be a temporary fix
but if no puddle, it is most likely just the clutch that needs replacing
May 26, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Washer not spinning enough to ring out cloths
I have the same problem with my Maytag LAT8506AAE machine. Do I need to fill up any oil after the seal replacement?
Jan 24, 2009 | Washing Machines
Kenmore 80 washing machine won't spin
No belts on that washer. You need a new clutch, the clutch cant grab the basket drive tight enough to spin. I will try to add a tutorial on it tomorrow. Look here for tutorial. www.shop.washermd.com Dave
Jan 05, 2009 | Kenmore 24902 Top Load Washer
Agitator does not spin.
The clutch needs replacing. The gearcase needs to be removed and the centrifugal clutch is mounted on the gearcase.
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 will not spin, but does drain
Sounds like you have a broken motor coupling. Click on the following link for instructions on how to replace the coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
These instructions will give you the necessary information to take the washer apart to get to the motor coupling to see if it has failed. A tell tale sign is black rubber dust particles under the washer where the drive motor is located. Usually the rubber bushing shears apart, or the plastic tines break off the coupling itself. If the motor coupling is broken a replacement can be found at searspartsdirect.com. Just type in your model number and the coupling can be found under the "Brake/Clutch/Gearcase/Motor/Pump" heading on the next page as item number 13. The part number is 285753A. This is a very simple repair job. If need further assistance, or have any questions please let me know. For quicker responses to your questions, please go to my profile and use the "Ask Me" feature. I hope this is helpful to you.
Jul 31, 2008 | Kenmore Washing Machines
Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
1,349 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
