Question about HP Pavilion ze4560us Notebook
Data Recovery My laptop starting making strange vibrating, almost grinding sounds whenever I would pick it up and hold it at the slightest angle. I feared the hard drive was about to crash so I began backing up my data onto an external hard drive. In the middle of the process, my laptop crashed and now will no longer boot up successfully. An error screen of some kind explained during a failed boot up that portions of windows were missing and that I needed to reformat the hard drive and reinstall the OS. I was in the process of backing up all my files when this happened so I really didn?t want to reformat and risk losing data. So I set out onto the internet to see if I could figure out some techniques for data recovery. I read somewhere online that I could try removing the hard drive and use an IDE to USB cable to access the weary hard drive with another computer and recover whatever data that is intact. I must have misunderstood the online information, which I can now not find again, because after ordering the IDE to USB cable and then attempting to use it, I discovered that the IDE cable quite obviously does not match the connection on the hard drive. I have no idea what the connection it is, it looks more like a RAM port with four little prongs in a square pattern on the side than the series of IDE prongs that I expected to find. It?s like a square peg and a round hole. I don?t understand. I thought all hard drives used IDE port, and if not I was pretty sure I read that my HP Pavilion?s hard drive had the IDE port. I?m obviously dreadfully ignorant in this matter and I probably have no business messing with this, but I figured the IDE to USB cable thing would be simple enough to try and avoid actually leaving the house. What kind of access can I have to my hard drive? Is there a cable I can get that will convert to USB so I can access my hard drive like an external hard drive?
    Genius:
  • 1,601 Answers
Try Tigerdirect for your cable.
Posted on Oct 22, 2007
I have a vibration almost like gears grinding
did ya replace the universal joints or just disconnect em and reconnect em ? I'll bet theres yer problem they got damaged in all the swapppng around an such also im guessing its 4wd so does it also have a rear bearing drive shaft mount as well (aka: half shaft) , ive seen these go plenty of times with the slightest of shaft flexes before
Mar 29, 2016 | Cars & Trucks
When I first got the phone I didn't set it up properly. How can I go back to the beginning and start fresh?
Don't know which phone you are holding. Normally, you can factory reset it to start over again. But remember to make a up for your data first. Or you can transfer data to another phone and move them back when you set it up properly with Gihosoft Mobile Phone Transfer . Whenever you need to restore lost data, please allow Gihosoft Android Data Recovery Free to help you.
Dec 12, 2015 | Cell Phones
My hard drive is asking to format how can i retrieve my data
Save what data you can to a different hard drive then format the unit . When finished reinstall the data from the drive to which you save the data
Feb 25, 2013 | Samsung Computers & Internet
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
My hard drive is making a strange noise when it is used. It sounds like a heartbeat and it occurs in a random time interval. I know it isnot much to start with but i cannot say anything else about it then...
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Western Digital 2 TB SATA 6 GB/s 7200 RPM...
Grind at 19 mph in primary
I would think that if the noise was being made by your transmission, it would start whenever you put the transmission in second gear and continue until you shifted to another gear, not at 19 mph only.
This sounds like a vibration that is specific to the engine rpm at that speed. It may sound like a grind but may actually be a vibration noise. Try to recreate the noise with the bike sitting still in neutral. Be careful not to allow the engine to overheat though.
Try other things to help you narrow down the source of the sound. When it starts, gently touch the brakes while maintaining the speed to try to eliminate the brakes. Does the noise change if you accellerated slightly or back off the throttle slightly.
It's very unusual for a transmission to make a noise in only one gear. I've found that if a transmission is making a noise, it makes the noise all the time but maybe louder at some speeds than others.
Good Luck
Steve
Jun 19, 2010 | 2006 Harley Davidson FXDBI Street Bob
Strange wurring sound and slight vibration at full speed Dewalt sds hammer drill dw25003.
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Aug 07, 2009 | Dewalt Drills
My External Hard drive is not recognized and makes sound
Have you tried connecting your external to some other computer or OS, will the same problem occur?
Well, in thiscase the MOST effective way is to try some so-called data recovery software to see if you can find some data back. Recommend you have a try of Wondershare Data Recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Feb 02, 2009 | Computers & Internet
HP Pavilion ze4560us Notebook Logo
321 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
