Washing Machine Emptying
The minute I turn on my washing machine and the water starts to fill up, it comes right out at the bottom and onto my floor. I don't think it's a hose leaking (though I could be wrong), because I think in that case, there would be a CONSTANT leak. With this there is ONLY water when the machine is running. Could there be a leak in the tub or something? I can't do a load at all because the water comes right out onto the floor. Help please! :)
  • tonyag9 May 28, 2009
    Thank you!! Now that I know chances are it is the tub, I think I'm just gonna get a new one. I actually bought this washer used 18 years ago (it's 70's avocado green and the same kind is even seen in the background on That 70s Show ha! lol), so I would imagine it is time :) I just didn't want to get a new one and then find out it was the line or something unrelated to the washer. Thanks so much for you help!
  • 864 Answers
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
Posted on May 28, 2009
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
Aug 12, 2015 | Candy Washing Machines
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Water running out
Is it from the water valve assembly or coming from under the machine? if it's from under the machine you may have a bad fill hose or a bad tub gasket, But I need some more info to help you.
Aug 07, 2009 | Frigidaire Washing Machines
The water will stay inside washer tub
Hi, What is the make/model# for this machine?
Did the water come out onto your floor?
I want to help.
Vic
Jun 20, 2009 | Washing Machines
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Washer Empties Immediately
sounds like you may have a hole inside the inner tub, depending on the model an the labor might be cheaper to buy a new one, i priced one for my old kenmore an was told 150 DLS. AM IN chicago, but i took it apart found the hole an sanded the hole with some sand paper, used a little piece of plastic patch looks more like a window screen an then used about 3 layers of JB weld an it fixed so far, is been working for over 6 months, knock on wood........lol.............good luck..........
LEAVE SOME FEED BACK LET ME KNOW!
May 27, 2009 | Electrolux EW1000i Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Water leaking out of washing machine Fisher Paykel
Hose has popped off or loose. Take the back off and watch it fill. You should be able to see where it's coming from.
Mar 08, 2008 | Washing Machines
Washing Machines Logo
190 people viewed this question
Top Washing Machines Experts
