Question about HP Business InkJet 2800 Printer
Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
I continue to get an error message on my HP business inkjet 2800 that tells me the NEW black cartridge is only 1% full. It's new, just installed when the OLD cartridge showed 1% ink left in cartridge, the new cartridge doesn't expire for 2 years was just installed this morning, so how do I get the brand new cartridge to quit reading at the old ink level? Thanks!
    Scholar:
  • 89 Answers
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
Why do I continue to get the E error message and blinking light on cartridges
The 'Ink Alert' or 'Low on Ink' message displays on the computer or on the product control panel.If the cartridge has been refilled or re manufactured, 'Low on Ink' or 'Ink Alert' or error messages appears on display panel.Replace with the new genuine cartridge which is showing error on display..
Nov 24, 2011 | HP PSC 1315 All-In-One InkJet Printer
I am getting a error message saying the printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume printing. I replaced the cartridges and it does not...
These printers have been known to have ink system failure errors. This message can also be caused by using compatible or re-manufactured cartridges. We believe the HP Live update software is also responsible for "dobbing" on you if you use any other brand.
A Fix for the ink system failure can be found below Not sure if it will help with your particular error but it wont hurt to try.
http://fix-your-printer.blogspot.com/2009/03/ink-system-failure-on-hp-photosmart.html
Good luck
Apr 14, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have not use the HP Inkjet 2800 for over 1 year. The first message reads" replace expired cartridge but when i check all the ink cartridge are nearly full. Please help! Matt S
Some HP cartridges actually have expiry dates on and they will not let you use them past this date. There is no way around this I'm afraid and you will have to purchase a new one. The use by dates are usually well in the future but sometimes if they are old stock or left for a while they can run out.
Sorry to be the bearer of bad news!
Nov 25, 2009 | HP Business InkJet 2800 Printer
My all-in-one printer A940 reads "error 50c" i have replaced both ink cartages what could b the problem?
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jul 17, 2009 | Dell A940 All-In-One InkJet Printer
HP Business Jet 2800 stall error message
See http://fixyourownprinter.com/forums/inkjet/42029
"Carriage Stall or Jam" by Stephen
Clean encoder strip with clean water, clean rod with denatured alchol you can get at Home Depot and lube with Synthetic Lubricant that you can purchase at a gun shop for about $4.
Mar 12, 2009 | HP Business InkJet 2800 Printer
HP BUSINESS INKJET 2800 SERIES OUT OF THE BOX WON'T PRINT BLACK
Usually this happens when the black cartridge is out of ink or when it is damaged.
Try to print with a new black cartridge
Dec 12, 2008 | HP Business InkJet 2800 Printer
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
HP Business Inkjet 2800 Problem
there is a sensor which recognises the amount of ink u have in ur cart. if that sensor doesnt work, then printer will not recognise the ink in the cart. Try cleaning the copper contacts on the printer cart slot. if no go. look for service..
Sep 25, 2008 | HP Business InkJet 2800 Printer
"Insert New Cartridge" Error Message
Sorry for the dumb & obvious question but did you remove the protective tape from the cartridge before inserting it. If so, then try returning the cartridge for a new one, you may have gotten a bad one. If problem continues you may have a printer problem. Also, you could reinsert your old one and see if you get the same error or an out of ink error. If you get an out of ink error the problem is most likely with the new cartrideg...if you get same error, the problem is most likely with printer.
Good luck.
Jun 03, 2008 | HP Officejet 4110 All-In-One InkJet...
HP Business InkJet 2800 Printer Logo
1,235 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
