Question about Electrolux EW1000i Front Load Washer
Washer Empties Immediately
The minute I turn on my washing machine and the water starts to fill up, it comes right out at the bottom and onto my floor. I don't think it's a hose leaking (though I could be wrong), because I think in that case, there would be a CONSTANT leak. With this there is ONLY water when the machine is running. Could there be a leak in the tub or something? I can't do a load at all because the water comes right out onto the floor. Help please! :)
    Scholar:
  • 91 Answers
Sounds like you may have a hole inside the inner tub, depending on the model an the labor might be cheaper to buy a new one, i priced one for my old kenmore an was told 150 DLS. AM IN chicago, but i took it apart found the hole an sanded the hole with some sand paper, used a little piece of plastic patch looks more like a window screen an then used about 3 layers of JB weld an it fixed so far, is been working for over 6 months, knock on wood........lol.............good luck..........
LEAVE SOME FEED BACK LET ME KNOW!
Posted on May 28, 2009
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
Ariston A1436 The machine begins to fill then empties and fails
Make sure that the top of the waste water pipe is at the correct height for the machine, typically around 30-34 inches from the floor (see your installation instructions). If it is any lower then it will start a siphoning action as soon as the water reaches the same level in the machine and never actually fill up and hence the cycle will not start. If the machine detects that insufficient water has entered the machine within a given time, typically 8 minutes, then if flags an error to the on board controller. If the error persists after the waste pipe height is corrected then check out the pressure switch for correct operation as if this is not triggered then the cycle will also not start or will halt almost immediately.
Oct 25, 2009 | Washing Machines
WHEN I TURN WASHER ON WATER STARTS POURING OUT OF THE BOTTOM OF THE MACHINE AND ONTO THE FLOOR. WATER IS COMING FROM THE BOTTOM LEFT SIDE.
The drum seal is bad. The seal allows the center to come up through the tub and the tub to rotate around it, It usually has a rubber membrane that flexes so the tub can rock around. The rubber tears and the water runs right out. If you can, disassemble the washer and change the seal, otherwise the washer is toast. Sorry! You can verify this by pouring water in from a bucket. If this water doesn't run through then it is the hose from the fill valve to the water outlet under the lid.
Jun 08, 2009 | Washing Machines
Washing Machine Emptying
Sure sounds like a hole or crack in the tub.  Unplug power, shut off water, and disconnect the hoses.  Tilt the washer onto its front and look underneath.  Use a light to inspect the tub bottom and sides for a hole or crack. If it is small enough you might be able to plug it with silicone sealant.
May 27, 2009 | Washing Machines
Top loaing washer fills then mostly empties repeatedly
Check you drain line. It may be too low or the air gap is blocked at the drain pipe.
A test is remove the drain pipe from the wall drain. Hold it up high and turn the washer on to fill.
If it fills and stops, then starts agitation. Repair the drain hose.
Mar 23, 2009 | Kenmore Washing Machines
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Electrolux EW1000i Front Load Washer Logo
160 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
