Question about Panasonic KX-TG6700 Phone
Panasonic KX-TG6700 - want to turn off/down a phone line
We no longer need the second line to ring at the base. Is there any way to turn down the volume, or shut off the ring at all for the base? I've turned it off on the handset, but it still rings at the base.
  • Brandon Dean May 27, 2009
    I think that did it, thanks for the help.
  • 68 Answers
Please refer to this link
http://service.us.panasonic.com/OPERMANPDF/KXTG6700.PDF
n look at page 38
hope this help.... ; )
Posted on May 27, 2009
test the adaptar if working try it in another phone
2) sure the the line cord is plugged firmly in the phone base
3) unplugged the phone base . Wait from 30 seconds, and plug it again. Allow up to one minute for the cordless handset and phone base to synchronize.
4) charge the batteries by 16 hours aprox.
5) if the batteries is completely dead can take 30 minutes before low battery appears on the screen.if doestnot work replace battery by new ones.
try agan.
Oct 03, 2012 | Panasonic KX-TG6700 Phone
Panasonic KX-TG6700
Did you try disonnecting the unit from the power for a few hours?
Apr 13, 2008 | Panasonic KX-TG6500 Cordless Phone
The line 2 ringer is off (it displayes message "ringer off line 2" on the number 2 remote phone panasonic kx-tg6700 & I cannot figure out how to turn it back on
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 20, 2011 | Panasonic KX-TG6700 Phone
I work for the Western Regional Day Report Center in Huntington, WV and we are using one of you Panasonic KX-TG4500 phones and Line 1 will light up when a call comes in, but WILL NOT RING. Now lines...
Check to see if the ringing volume is turned down,
On the base unit press the menu button and scroll to ringer settings using the up and down arrow keys, press the enter key.
Scroll down to ring group and press enter.
Press the left or right arrow keys to select the line desired.
press the down arrow key to move to Ext #.
Enter in the disired extension number starting with the base as Ext 0.
press enter to save.
Apr 05, 2010 | Panasonic KX-TG4500 Phone
Message problem
In your case there is no problem regarding your cordless phone. The problem might be in your network only. So please contact your network officer immediately.
Mar 18, 2009 | Panasonic KX-TG6700 Phone
Cordless phone does not work
ok i found a solution...
for good measure, unplug everything from the main base, wait a few minutes, then plug everything back in. this never solves the problem, but it's standard troubleshooting procedure.
next, follow the menu instructions on the non-working handset to re-register.
if the re-registration doesn't work, your handset is probably shot. you can buy a reconditioned one on ebay for under $30. take the battery out to find the model #.
Jan 10, 2009 | Panasonic KX-TG6700 Phone
Panasonic KX-TG6700
I have the same problem and I simply open the base (5 screws at the back), disconnect the cable that came from the keypad located (if you see the station from the back) at the left, turn on the base without connecting this cable. After that, I unpluged the station, reconnect the keypad cable and connect it again. Solved.
Jan 21, 2008 | Panasonic KX-TG6500 Cordless Phone
Unable to Play Messages on Base Unit
I called Panasonic on this problem....ended up sending the unit back for a free replacement. Guess thats the solution for this problem.
Dec 07, 2007 | Panasonic KX-TG6700 Cordless Phone
Panasonic KX-TG6700 Phone Logo
353 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
