Question about Villeroy & Boch 98M2 S1 01 Bellevue Toilet Seat & Cover White
Villeroy & boch flush mechenism needs to be replaced
Were do you find part to repair a villeroy & boch toilet. the water continues to run and trickle into the bowl after each flush
  • 3 Answers
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
Posted on Jun 29, 2009
    Scholar:
  • 102 Answers
V&B US phone number is or used to be 877-505-5350 they should be able to help.
Posted on May 26, 2010
Tank Cover
online by asking same question on web.
Mar 31, 2014 | Villeroy & Boch Villeroy-Boch Colani...
Villeroy & Boch flush tank doesnt get water
Hi pervana....
You have an obstruction in your ballcock/inlet valve or the ballcock/inlet valve is malfunctioning and is need of replacement.
Try to move the float up and down inside of the bowl, this may loosen the valve and allow water to enter the tank.
If this does not solve your problem then you will need to replace the ballcock/inlet valve.
Free Answer...Please take time to rate me
May 16, 2011 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
Villeroy & Boch Sunberry close coupled pan and Subway cistern newly installed at the end of July 2010. When flushed the internal mechanism does not always drop down to stop the inlet water....
Your chain is probably metal that snags under the flap (verify by taking top off tank and looking) and you should switch to a plastic chain.
Easy just replace the flap that stops the water after handle is down and toilet flushes and also replace the chain that connects from handle to rubber flap. New chain should be plastic one so it can be reattached and problem is fixed. Should cost less then 5 bucks from Home Depot or Lowes. They can happily step you through the process. I should take about 2 minutes to install ...if that.
Remember to remove excess links of plastic chain with a pair of scissors. Its doesn't require a rocket scientist.
Oct 06, 2010 | Villeroy & Boch 6610 11 Subway...
Leaking water into bowl
Your question has been posted under the heading of Villeroy & Boch. If this is the brand you are working on then the flush valve is set up like the old Mansfield Fush valves and is replaced in the same way. But if VB is the brand you might try calling 877-505-5350 it is or was their US number. Hope this helps.
Mar 29, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
My Villeroy and boch toilet's water level inside the toilet is always low. I was seeing if there was a way to increase the level inside the toilet, not the tank.
V & B toll free number was 877-505-5350. I hane only worked on one in 25 years and they were very helpful. Hope this gets you in the right direction.
Feb 09, 2010 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have the bellevue model and it keeps running even when the toilet has been flushed. It continuely seems to need more water and leaks a bit of water all of the time. It is a new toilet!
Your flapper is not sealing at the bottom of the tank. You can either return the toilet, replace the flapper, or try smearing a little vaseline on the underside of the flapper lip where it contacts the tank bottom. The latter may be all it needs to seal a tiny leak.
Dec 03, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
My V and B toilet suddenly stopped flushing today, what's the problem?
It won't drain? Is the tank draining? Is the water turned off? Or is it just plugged up?
Jun 19, 2009 | Villeroy & Boch 6610 11 Subway...
Villeroy & Boch 98M2 S1 01 Bellevue Toilet Seat & Cover White Logo
996 people viewed this question
Top Villeroy & Boch Home Experts
J.D. Browning
J.D. Browning
Lisa Zhuo
Lisa Zhuo
Level 1 Expert
Are you a Villeroy & Boch Home Expert? Answer questions, earn points and help others
