Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
LP gas conversion oven flame to big
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top burners seem fine but when i go to use the oven the glowing igniter works and when the gas valve opens the flames are i belive to big. They reach into the oven area through the ovens bottom vents. The instructions have me turning down the "Spud" on the "Oven burner orifice" counter-clockwise until snug against the "LP/propane metering pin" arund two and a half turns. I dont want to break it but you really cant see the top of the lpgas metering pin. Any help would be great Carlos Nunez
  • nunez110 May 28, 2009
    Thank you foster477.... I was afraid i would break it but i guess it needs a bit more....Thanks again.
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
  • sue_grant100 Nov 27, 2009
    Tighten A LOT....It worked!!
    Problem Solver:
  • 13 Answers
Tighten the spud all the way down till its snugg not really tight
Posted on May 27, 2009
Preformed the Natural to LP conversion but the oven flames are to high
Part of the conversion would include screwing the oven gas valve orifice clockwise until snug. Then adjusting the air shutter to achieve the best flame.
Were these steps done?
Feb 12, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top...
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Jan 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
Gas range burner flame too high and too yellow.
Did it work OK in that location before the changes?
Sounds like you used Natural gas parts instead of LP.
Lp orifices have smaller holes than Nat.
Mar 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Sooty burning in oven after Natural-LP gas conversion
The conversion was not done correctly.
Either wrong parts or incorrect adjustments to air flow.
Feb 08, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven flame is too high
the flame should be app 2" from each side of the burner. be very careful with lp conversions.
Feb 09, 2008 | Frigidaire GLGF382D Gas Kitchen Range
Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Aug 23, 2007 | Hotpoint RGB745 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Changed from natural gas to propane when new oven flames up the side top burners ok
Just bought a Kenmore and did this conversion myself. You do not change the oven nozzle (jets) but have to wrench it down with a 1/2" wrench as per instructions. After I did this the falme was high as you described. I wrenched it down further and adjusted the air shuttle and it was fine. The brioler is done the same. The wrench adjustment is tight so be aware.
Apr 08, 2007 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
1,217 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
