Question about Whirlpool LEQ9858L Electric Dryer
I've just purchased a used dryer, and unfortunately it makes a steady whining noise while it's running. It's driving me nuts.
I've just purchased a used dryer, and unfortunately it makes a steady whining noise while it's running. So far the drum is turning and the heat element is heating the clothes...but the noise is driving me NUTS. :) It's a Whirlpool model: LEN2000PWO electric clothes dryer. Please help!
  • 56 Answers
Sounds like youhave something in the blower wheel. if your dryer has a front removable lower panel with a putty knife on the left and right sides 1 inch in from the sides slide putty knife in to release catches. two screws hold the bower housing on then you can look at blower wheel. if it doesnt have removable panel then youmust access it from the back access panel then on left side take out 4 srews that hold blower cover on and pull back as far as youcan without bending top and look inside with a flashlight.. remember always unplug unit
Posted on May 29, 2009
Noise in primary
You'll have to remove the primary cover in order to see inside. I would check the compensating sprocket nut. They have a tendency to loosen up for some reason, and that causes a strange noise. Check that first. Second, check to make sure your automatic chain tensioner is working properly. We've had some in the shop that ran the chain too tight, causing a loud whining noise.
Sep 12, 2012 | 2010 Harley Davidson FLHTK Electra Glide...
How to troubleshoot noise coming from dryer
A whining noise could be either a worn drive belt on it's way out or a piece of clothing trapped at the back of the drum. To check this, you can unplug the machine, unscrew the lint trap on top of the dryer and using a flathead screwdriver, pop the top off the dryer. Once the top is up, you should be able to inspect the drive belt and be able to feel around the back of the drum for any debris or clothing. If the belt requires replacement, you will need to unscrew the front of the dryer to get the front panel off.
Dec 16, 2011 | Whirlpool Washing Machines
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have a 2002 chevy surburban and it makes a whining noise.
the noise happens running down the road or parked? Is the car a four wheel drive? The alteanator can go bad and whine, the wheel bearings can go bad and whine, windows not fitting right can make a whine The altenator will stop whining if it's unplugged, if this fixes it the battery and the altenater need tested and a bad battery can make the altenator whine and it still be OK. Don't run the engine with the battery disconnected as this can blow alot of expensive stuff and the altenator.
Sep 28, 2010 | 2002 Chevrolet Suburban
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Whines when in operation
Sorry, but I don't have a solution, but I share this problem with my Whirlpool Model DU1145XTPBA, which I assume is essentially the same model. It started a couple of weeks ago, and it's about to drive me nuts. The whine is more or less steady, and quite loud, as long as the motor is running.
I dread having to spend the money on a new motor/pump assembly, plus the joy of replacement, and I'm hoping there is an easier, simpler, less expensive alternative.
Aug 19, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dryer is making a whining or squealing noise when in use.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
789gdsf
Aug 07, 2009 | Bosch Nexxt 500 Dryer
Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool LEQ9858L Electric Dryer Logo
203 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
