Question about Dell Inspiron 1501 Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
Laptop screen goes black when trying to brighten using ac power I HAVE A DELL INSPIRON 1501 WHICH I'M USING RIGHT NOW. MY ONLY PROBLEM IS THAT MY SCREEN IS TOO DARK. I HAVE TO HOLD THE LAPTOP IN EXTREME LIGHT IN ORDER TO VIEW WHAT'S ON THE SCREEN. HELP!!
  • feliciaben May 27, 2009
    where is lcd located
  • 489 Answers
There is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
Posted on May 27, 2009
  • meteshadow May 28, 2009
    usually bottom side. but dont touch maybe it will be out of garanty.
Dell inspiron e1545 screen goes black when using battery power
If the battery is good, mine died after 4 years, check the settings in Power Options, look for dim when on battery power. Increase the % to Max or 100%. see what happens. Still have problem consider replacing Battery.
Oct 29, 2012 | Dell Inspiron Computers & Internet
My 1501 Dell Inspiron turns on but I have a blank black screen. The only light that shows is the power light on the upper right side of the laptop.
Power getting to the laptop. Try first to see if this will give a screen image on an external monitor, listen for the sound of the cpu fan, hard drive and DVD rom drives clicking, see if the DVD rom drive will open if pressed.
Then remove battery and AC adaptor, press the power button for 30 secs, refit mains only and try this on mains supply (no battery)
If this fails to boot, check the light on the ac adaptor is a steady green, flashing green indicates power is not fully reaching the laptop (motherboard problems)
If it is steady and the LED power light on the laptop is steady, suspect the DC jack socket. If this feels loose or sloppy, it will need replacing, depending on the type fitted, it may be soldered onto the board, or a wired connector, which sometimes goes bad.
After that, I'd suggest that a capacitor has gone on the actual motherboard and you will need to strip the laptop to check it.
Jul 18, 2011 | Dell Inspiron 1501 Notebook
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
My dell inspiron screen stays black and powers up
Try this
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
You might also try an external monitor and see if you get any video that way (Fn+F8 toggles to enable external video)
Jan 05, 2010 | Dell Inspiron 1501 Notebook
No power to computer . Ac adaptor plugged in and power point ok- just no power at all to computer- wont turn on.
If the power point is ok try using another AC adaptor of some of your known person who is using the same laptop, and check it should work else the fault will be with laptop and you need to get the same checked at the service center,
make sure you do not open the laptop on your own as you may loose the warrenty of the same
Let me know if this will help
Regards
Nov 29, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 laptop with AMD 64 processor: Black Screen
Go to Control Panel/Power Options and check the settings. It's probably set to shut off after a period of time.
Oct 31, 2009 | Dell Inspiron 1521-JB Notebook
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron E1705, Faint Black Screen on Battery Power
the first thing i would do is do a bios update for the machine whilst using AC power, that may well iron the problem out, if not then there is a problem with the laptop itself i.e. a power drain, sizzling and popping noises is not good at all and could damage the machine further, remove the battery and check the connections on the laptop, dust and hair conduct electricity, it could be as simple as that, it is also a known fact that some lithium batteries are faulty and have been known to blow up whilst in use.
Go to the laptops support website to find out if they have been having problems with batteries and if there any returns proceedures
best regards
Nov 17, 2008 | Dell Inspiron 1501 Notebook
Black screen
It seems your Operating system has corrupted, Its best to use Windows Installation CD to perform Recovery Installation. You can Use the DELL Disk. Before proceed Make sure you have your backup. If you need some advanced access to files you can use UBCD.
Good Luck
Jun 19, 2008 | Dell InspironTM 1501 Notebook
Dell Inspiron 1501 Notebook Logo
344 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
