Computer does not recognize the hard drive. I've installed a new one thinking that the old one didn't work
I have a dell inspiron 5100. When I turn it on, it beeps twicw andthe screen is black with the following messages on it Primary hard disk drive 0 not found No bootable devices--strike F1 to try reboot, F2 for setup utility I've installed a new hard drive thinking that was the problem but with the new hard drive I still get the same message
  • 489 Answers
Your mainboard is broke down. it doesnt see HDD.
Posted on May 27, 2009
Dell inspiron 3847
Dell has not published the procedures for installing an additional SATA hard drive, the Inspiron 3847 has a second 3.5" bay, for the second hard drive next to the primary hard drive, there should be a set of rails located in the bay, two 6-32X1/4, phillips head screws are needed, to attach the rails.
The procedures on pages 26 to 28 of the owners manual should give you an idea of what is required for the installation.
http://ftp.dell.com/Manuals/all-products-Infodev/esuprt_desktop/esuprt_inspiron_desktop/inspiron-3847-desktop_Owner%27s%20Manual_en-us.pdf
You will need a SATA data cable there should be a spare SATA power connector inside the case.
After installing the drive enter the system setup and check that the hard drive is 'enabled' [on] and recognized.
For Windows to recognize the second hard drive, it must be partitioned and formatted.
Go to Control Panel, Administrative Tools, Computer Management, Storage, Disk Management, right click new drive, select format, then you can assign a drive letter.
May 08, 2014 | Dell Computers & Internet
After installing windows 7 my cd drive doesn't work. I've tried new drivers and disabling it and everything else I can think of... can anyone help?
Are you sure that you have installed the correct driver? Try going to the website of your computer's manufacturer and get the driver from there.
David
Mar 26, 2013 | Dell Inspiron 1525 Notebook
I installed a new hard drive in my PC. It installed itself after I turned on the computer but it doesn't seem to show up on My Computer as a individual drive. BIOS and the Sys Info recognizes there is a...
Are you sure your BIOS is not showing the old hard-drive you had before you installed the new one?
On the new hard-drive you bought, do the following step
there should be a jumper that came with it, put the jumper to "master",
if that didn't work, put it to "slave", if that didn't show up, put it to "cable select" and try it.
If all failed, totally remove the jumper and try.
Also check in the BIOS to make sure that the Drive is not disabled.
This seems to be a problem from the jumper.
Please rate 4 stars if this helped you.
Apr 26, 2011 | Seagate HDD 1TB 7200RPM SATA600 32MB 3YR...
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
New computer doesn't recognize device
uninstall the drivers for the hard drive then reboot install drivers that came with drive and then plug it in.
Mar 27, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Hello, I get the folliwing message by starting my laptop dell inspiron 5100: The operating system not found. Please could you provide any solution to solve the problem. Thanks. Chahin
this happens when there is damage to the windows installation, or the hard drive itself. test your hard drive using an external hard drive casing, if the hard drive works then you can just copy your files to another computer, then reformat the hard drive put it back in your laptop and reload windows
Oct 03, 2009 | Dell Inspiron 5100 Notebook
I have an Inspiron 5100 that is running very slow. I want to format the hard drive (40 GB)and reinstall XP Home. I hit the F12 key while booting and the computer tries to boot from the CD drive but it does...
This would be a good time to upgrade to Windows XP Professional. I think your disk from Dell is bad because you are going about it the right way.
One suggestion is to put your windows cd in the cdrom drive. Browse the cd for a file called setup, click on that and setup should run from there.
Aug 14, 2009 | Dell Inspiron 5100 Laptop
No bootable device--strike f1(please help)bios wont read cd or hd
I think your lap top fails to detect your hard disk. Enter Bios settings and confirm that the hard disk is detected.
Mar 25, 2009 | Dell Inspiron 2200 Notebook
External Harddrive not recognized.
perhaps this new computer has usb 2.0 while the old dell was of older standards.check whether the external hdd supports usb 2.0,,if it do so,,buy a usb 2.0 cable and start using it.best of luck
Jan 16, 2009 | Western Digital Caviar SE WD5000AAJB -...
Dell Inspiron 5100 PP07L hard drive
Did you accidentally buy a SATA notebook drive?
If so, this will not work in your notebook, it used IDE drives.
Jan 19, 2008 | Dell Inspiron 5100 Notebook
Computers & Internet Logo
542 people viewed this question
David Payne
David Payne
