Question about Philips gemini XL-500 II Turntable
Turntable will not hold pitch,speeds up or slows down.
Gemini XL 500II turntable will not hold pitch,it either speeds up or slows down making it very hard to mix.Can this be fixed?
They arte direct drive though so smirf617 how will that help ?
Posted on Aug 05, 2010
  • 104 Answers
Try replacing the drive belt with brand new one and see if this improves the situation
Posted on May 28, 2009
4 Suggested Answers
djtatty
  • 417 Answers
SOURCE: I own Gemini TT01 belt drive turntable, as time
Take the platter off & tietern the bolt that holds the spindle pin to the motor or in your case the base.
if you carnt get to it by taking off the platter then u will have to unscrew the base & get to it that way.
OH & dont forget to unscrew the feet coz they hold the corners together.
& good luck mate coz Theres alot screws to take out.
if u get stuk E-Mail me.....
Posted on Aug 08, 2009
  • 5 Answers
SOURCE: sound wavers (speeds up and slows down)
you need to replace the Pitch controls. I'm presuming it is a sliding pitch control. Use the Red start stop lights that reflect on the rotating wheel. put the pitch in center 0. does one row of the dots on the wheel stay completely still.now just turn it up op down a bit until it starts to move the dots slightly. now watch the dots now while there moving. Do they fluctuate they should be smoothe. do this on both decks to find out which one is fluctuating.
Posted on Nov 07, 2009
djredskyy
  • 670 Answers
SOURCE: Where can I find a
www.shure.com www.ortofon.com best needles around
Posted on Jun 01, 2011
How to fix flutter & wow on a Gemini 500 XLii direct drive turntable
Direct drive turntables have electronically controlled speed. If the records you are playing are warped (not flat) that will cause wow & flutter. If that's not the problem then you might try connecting the turntable to a different power outlet using a long extension cord. Failing that, the turntable needs repair.
Jul 30, 2014 | Philips gemini XL-500 II Turntable
Where to get a needle for Gemini XL 500 II
Look at the cartridge make and model number fitted. Put that into Google and the type of stylus needed will show up.
Jun 29, 2014 | Gemini XL-500 Turntable
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
I have an Gemini XL-100 ( only the turntable itself) , and I am wondering what are the missing parts I need to make it work properly.
I don't understand what you mean. Are the electronics parts missing does it have a power supply or is it just the cartridge that's not there?
Aug 13, 2013 | Gemini XL-100 Turntable
Where can I get needles for my gemini xl-500II?
You need to look at the Cartridge installed then post that model number in Google.
Feb 06, 2013 | Audio Players & Recorders
I have two Gemini XL 500II turntables that are missing the power cords can you help me?
Is there something 'special' about them? Power cords are common. Take one to an electrical supply store, radio Shack or just look around the house for an unused one.
Jul 05, 2011 | Gemini Audio Players & Recorders
Issues with turntables picking up speed when trying to time start off. It's hard to match beats when the table does not start on cue or slowly try to catch up to speed. What's wrong with them?
This seems to be a pitch control issue. controller,
replacing \t,could be worn over time,
SL1200 Technics - if you want a solid long lasting excellence of sound reproduction for many years to come,
I had the same pitch control issue,
happened on one of my decks so I replaced the controller and good to go from there,
Another important tip -
never lubricate the controls sliders with any thing apart from the correct greases or oils applied by the manufactuer,most people dont think of the damage caused by the cleaners they use ,some aerosols eat away the fine oil that lubricates the pitch control sliders making them dry and brittle eventually cracking producing odd random performance issues,
hope this helps,cheers Misterdj
Apr 08, 2010 | Philips gemini XL-500 II Turntable
Sound wavers (speeds up and slows down)
Jul 10, 2009 | Philips gemini XL-500 II Turntable
Quartz accuracy not accurate
Sometimes it's down to the mains in the country you are in. Some decks change speed from 50HZ to 60HZ.
Dec 07, 2017 | Audio Players & Recorders
Gemini xl 500
on top of the pitch control there is a small hole, in this hole you can use a small screw driver  and turn it left and right to free any dirt inside this is the master pitch control
Aug 10, 2008 | Gemini XL-500 Turntable
Philips gemini  XL-500 II Turntable Logo
1,572 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
