Question about Roland Office Equipment & Supplies
Roland scan motor error 0040 0040
Roland 540i motor error 0040 ? what to do?
Error 0109
hello Arnie
do you have already a solution for your problem?
Nov 25, 2013 | Roland VersaCAMM SP-540V
Sounds like the motor is jammed.
This is a scan motor over current error where a large load is put on the motor movement instantaneously. Turn the power off, clear any media jam that may have occurred and turn the printer back on. If the error continues, please contact your local Roland Service Center.
Jun 17, 2013 | Roland Office Equipment & Supplies
Motor error 0010
Estou com um erro na roland RS 640. Erro service call 0109!
May 20, 2013 | Roland Versa Art RS 640 64-inch Printer
Sum error roland vp 540
hello, je viens de remplacerla carte m?re de mon Roland sp-540v et la machine ? l allumage m affiche sum error, aidez moi ? r?soudre cet error
Mar 18, 2013 | Office Equipment & Supplies
Printing problems
roland rs-640 error motor code 0010 0010
Dec 03, 2012 | Office Equipment & Supplies
Analog test eror onroland td5
I have the same problem with my module and I can\'t find the solution anyware for the thing.Closest solution that I could find is something about Roland power adapter.Apparently module won\'t work with any adapter with the same voltage,only Roland or Boss B.R.A. adapters works.I have original Roland adapter and still shows an Analog test error.
Have you find the solution in meantime by any chance?
Sep 09, 2012 | Roland Music
I have a Roland Versacamm and as it's printing an image that is supposed to be a rectangle shape 40"x60"...as it prints out the image is not straight it actually looks wavey like a flag? The printer was OK...
this sounds like a scan motor error. clean encoding strip and test. If still wavy remove scan sensor the one that reads the encoder strip, clean with alcohol, replace and test. if still bad replace encoder strip and the eye that reads it.
Aug 02, 2008 | Roland Vs-2000CD Digital Studio...
165 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
