Question about Logitech Harmony 880 LCD Remote Control
Oneforall remote cannot get it too change channels all the lights go on and i put new batterys in it please help me
  • 129 Answers
Re: oneforall remote
Hello, do you know if you have the right code for your remote programmed into it?
if not try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Posted on Dec 23, 2007
0 characters
3 Points
Retune with oneforall remote
look for a menu button and try to find install and retune on the menu
Mar 03, 2013 | Remote Controls
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Remote Controls
I changed the batteries in the oneforall remote control, I can get the buttons to work, and light the little red light at the top, but it won't change the channel, or raise and lower the volume, or turn on...
When you removed the batteries, you drained the memory. You will now need to reprogram the unit. That might be a problem if you don't have the original manual that came with it (probably not much more than a sheet of paper.
Easiest way to fix the problem would be to buy one of those JUMBO remotes at CVS or Walgreens. They are only about $10 and since they are oversize they would be the perfect thing for an elderly person. Big keys and bigger case so it will be easy to find.
Good Luck
Mar 13, 2011 | One For All URC4220 Remote Control
Why wont my Dish network remote change the channels. Ive already put new batteries in it
When you replaced the batteries in the remote, does any light on the top of the remote light up when you press the select button? If any light other than the SAT button lights up, press and release the SAT button to put the remote back into satellite mode, then try the remote to see if it functions correctly. If none of the buttons light up, make sure all batteries are lined up with the + (positive) facing down. If they are, you may need to readdress the remote to the receiver. I hope this helps.
I have provided a link with instructions on how to readdress the remote to the receiver. Step 4 is for address the remote to the receiver. If you have any problems, please let me know.
Readdress remote to receiver, step 4:
Ray Calo
DISH Network
Feb 19, 2011 | DISH Network IR Remote Control
I have a hugh, older model, 2000 Toshiba TV, but I can't find a remote to work it. I have purchased a dozen or better and no good. I have 2 Toshiba TV remote controls. I donot know weather they go with...
If you only want to control the volume and channels, then a "Oneforall" remote will work. If you want to sell the toshiba vc-661T remote, email me.
Feb 07, 2011 | Toshiba Remote Controls
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
Sharp tv /oneforall/remote control
Press code search button,The indicator light go on.Press the TV button opiton the light will blink.Sharp TV codes 173,095,171,004,006, 012,029,111,112,113,122.After your code is entered,the indicator light will turn off.Aim the remote at your TV and press the ON/OFF button.Your TV should turn off or on.Tries each code until u have ur code.Please rate me after,
if I help U.
Aug 29, 2009 | One For All URC-4330 Remote Control
Logitech Harmony 880 LCD Remote Control Logo
156 people viewed this question
Top Logitech Remote Controls Experts
bill tarkulich
Level 1 Expert
Ron Dufek
Ron Dufek
Level 1 Expert
Are you a Logitech Remote Control Expert? Answer questions, earn points and help others
