Question about Hayward SAND FILTER, PRO SERIES
Sand filter problem
I have a sand filter that runs a well for a day or two then it needs backwashing. its new sand and the pump runs at 800gl a hr on a 650gl pool for koi. why have i got to backwash so much? thanks in advance for any help.
  • rivers351 May 28, 2009
    great, that is what i was thinking. thankyou for the info.
    President:
  • 1,902 Answers
The pump is to big for the pool. So with that being said it is asking you to back wash more then you should need to because it is pulling water at a much higher rate then what your pool is actually calling for. I would recommend taking it down to a 700gl and this would solve your problem. Also you can replace the drain lines and suction lines to smaller lines and that will also take care of the issue at hand but I do not recommend that at all
Posted on May 27, 2009
Tip
Backwashing A Sand Filter with A Push/Pull Slide Valve or Multiport Valve
Lots of people are first time pool owners and pool professionals forget to teach these "newbies" about the simplest aspects of pool ownership.
One of the biggest questions we receive from new homeowners is "How do I go about backwashing my sand filter exactly?"
It doesn't matter if you have a Hayward, Pentair, Jandy, Sta-Rite or any other number of Sand Filters on the market they all utilize the same basic valves for backwashing; a push/pull slide valve or a multiport valve.
To backwash with a multiport valve:
1) Shut off pump motor.
2) Press down on valve handle, rotate valve from FILTER to BACKWASH position.
3) Roll out any backwash hose or open any waste line valves.
4) Open air bleeder assembly on filter, and turn pump on.
5) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
6) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
7) Shut off pump motor and move multiport valve handle to RINSE position. Run on rinse for 15 - 25 seconds.
8) Shut off pump motor and move multiport valve handle to FILTER position.
9) Turn pump back on and note lower pressure.
10) Roll up backwash hose so the dogs use it as a chew toy.
To Backwash a sand filter with a slide valve:
1) Shut off pump motor, roll out backwash hose.
2) Twist to unlock plunger T-handle, push or pull(depending on manufaturer) the plunger 2" - 3".
3) Open air bleeder assembly on filter, and turn pump on.
4) Watch pressure gauge for backpressure and hose for kinks. Be prepared to shut off pump quickly.
5) After hose fills with water, run for 3 - 5 minutes or until water runs clear.
6) Shut off pump motor and push T-handle back down into locked position.
7) Turn pump back on and note lower pressure.
8) Roll up backwash hose.
Now you are a backwash Guru!
More tips and tricks are available form The Ugly Pool Guy, www.WeFixUglyPools.com
on Dec 14, 2010 | Pool & Spa
Why does the filter basket never seem to catch anything and it never reads to need to be backwashed...but the water is still not clear....what are we doing wrong?
Because of the size of the filter - 18", I would presume this is an above ground pool?
  • Do you have a skimmer?
    • If so, put some leaves, larger organic debris, etc. into the skimmer. They should end up in the basket of the Hair & Lint Pot!
    • That would prove your question to be either working or not.
  • If you don't have a skimmer, then you have a suction port in your pool.
    • Let that suction port suck some larger debris that would stay in the basket. Again, you will prove or disprove, whether debris is getting to your pump basket (Hair & Lint Pot Basket).
How long has your pump & filter been operating?
How long do you let your pump & filter run per day?
  • It should run at least 8 hrs per day.
  • If cloudy, you should run continuously until clear.
How long has your water been turbid/cloudy?
  • Use a clarifier, Natural preferred, like SeaKlear, daily at recommended dosage, until clear
What is the pressure?
Are you saying that it is the same pressure as Day 1, has not climbed at all?
What do you mean: Does not read that backwash is needed?
What in your understanding is: "Time to backwash the filter"?
You should know the "Starting Pressure" of your Sand Filter!
  • When sand is absolutely clean & free of any grime and sticky residue.
    • Just added media, when just installed is the best time to make a note of the starting pressure on a working pressure gauge.
  • When the pressure rises 8-10 lbs. over starting, time to backwash!
Jul 13, 2014 | Hayward Pro Series 18" Above Ground Pool...
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
When backwashing...sand discharges out backwash hose..
A little sand in backwash is not uncommon. Many packaged sand filter systems use pumps whose flow rates greatly exceed the flow capacity of the filter.(the more horsepower the better, right? - Wrong) If this occurs only during back flush the the pump is too strong or the sand level is above the beginning of the rounded top of tank. The sand level will eventually correct itself.
Aug 10, 2012 | Hayward SAND FILTER, PRO SERIES
Started sand filter wrong
Just run it and vacume you will collect all the dust. If you used Zeo sand or like product instead of sand, you will need to backwash, run and backwashtwo or three times.
Jun 28, 2010 | Hayward SAND FILTER, PRO SERIES
My Hayward Swimpro Sand filter is not backwashing
Be sure it is not plumbed backwards and be sure you got a sand valve as a DE plumbs the other way.
Jun 25, 2010 | Hayward SAND FILTER, PRO SERIES
Pressure up past 15 or 20 shortly after
The sand is clogged and needs a backwash or change.
May 25, 2010 | Hayward Pro Series 18" Above Ground Pool...
My pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
May 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Sand filter not catching little debris
Filter is being bypassed at backwash valve, due to poor spider gasket in valve, or there is a broken lateral in bottom of sand filter, causing debris to return to pool..
Feb 18, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
307 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
