Question about Gateway GT5408 PC Desktop
Tsst-h652d not working after upgrade, thinks its a cdrom not combo
My Gateway GT5408 has a TSSTCORP CD/DVDW TS-H652D ATA rom drive that has stop working and I have tried to update the drive and still come up with nothing PLEASE help. My pcs a Gateway 5052b, i flashed the bios to enable 4g memory instalation and after upgrading from system disk to xp pro , the h652d will only show as a cd rom in properties but not on control panel wher it shows as a dvd ram aaaaaargh!!!!!
  • 2 more comments
  • rhodes86 May 27, 2009
    tried removing lower/ higher filters using regedit , no drivers available but have not tried uninstalling and removing ide cable, will try that now. I have tried to flash using sfdf win but it says the bin file isnt compatable , thanks mikki
    Just tried it , came up with found new hardware TSSTCORP CD/DVDW TS-H652D then come again with found new hard ware cdrom, also listed in system as TSSTCORP CD/DVDW TS-H652D but properties state its just a cdrom. Can watch dvds on it but nable to burm any kind off media , think its time for a new cd/dvd drive. thanks for the help miiki
  • Peter Steiert
    Peter Steiert May 11, 2010
    Yeah, sometimes the flashing doesn't work since these companies don't bother supporting old products. Let me know how it works out for you. Typically giving windows a second chance to recognize something will yield better results.
  • Peter Steiert
    Have you attempted to remove it from the Add/Remove Hardware wizard, shutting down, removing the IDE cable from the drive, restarting, shutting down, attaching the IDE cable to the drive, starting up, installing firmware/drivers?
    Sergeant:
  • 219 Answers
Well, I'm sorry it didn't work out for you. It was still worth a try. I have to agree with you. Since it isn't being recognized properly it probably isn't worth the trouble getting it repaired since typically that costs more than buying a new one. If you need to find some good prices on CD/DVD readers & burners you can look online here:
Newegg
Simply navigate to Computer Hardware > CD / DVD Burners & Media. After the page loads simply click, "CD / DVD Burners" located in the menu on the left.
Let me know if I can do anything else for you (posted as a solution so you could rate the responses above).
Posted on May 28, 2009
TSSTcorp CD/DVDW TS-L632M ATA DEVICE
Use your Make, model at Laptop's manufacturer's website, you didn't supply, and install driver for the DVD rom drive.
Feb 04, 2013 | HP Pavilion Computers & Internet
CD/DVDW ROM drive won't start
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Jan 25, 2012 | Gateway Computers & Internet
Error with a TSST CD/DVDW TS-L532U.
Try uninstalling the device using device manager. Shutdown computer and restart. If the problem persists then you have a faulty DVD/CD drive.
Go to My Computer and right click, select the Device Manager, search for the drive on the right side. Right click and choose Uninstall. then restart. Hope this helps.
Jun 13, 2010 | Computers & Internet
Tsst corp cd/dvdw ts-652d ata device not found
your CD-ROM/DVD-ROMs require no drivers   install Nero and see if it works  if not  check the wiring  if it has IDE cables make sure the jumpers are correct for the situation  make sure they are 80 pin cables not 40 pin and that the poer is plugged into the drives  sometimes if Patin-couffin is installed it may fix things
Oct 20, 2009 | Gateway GT5435E Refurbished AMD Desktop...
How do I install a TSST corp CD/DVDW TS-L632D ATA device
It should just plug in and windows will reconize it.
Sep 25, 2009 | Computers & Internet
GT 5411E TSSTcorp CD/DVDW TS-H652D ATA Device code 39 error
i have six gateway desk tops in the house now.thats all i buy and some dell newer stuff.
gateway charges a fee after the warranty exspires.joke huh:?
Jun 14, 2009 | Gateway GT5408 PC Desktop
TSST Corp CDDVDW TS-L632N ATA DEVICE
Try to uninstall your optical drive on device manager and restart your system.
->if that doesn't work try a firmware update.
->if that still doesn't work,replace optical drive.
that should resolve your problem
May 29, 2009 | HP Pavilion DV6700T Notebook
Code 39
enter in to bios
and make sure it can see the CD drive.
if it can see it ,neither can windoz.
if it cant.
and it is the only CD or dvd drive in DT.
then
set the jumper on the drive to
Master. with the jumper
and make sure cable is plugged in to HDD1 IDE cable. and plug on MB.
try a barrowed ancient cdrom ,see if it identifies.
if it does ,yours is bad.
Apr 29, 2009 | Gateway GT5408 PC Desktop
My TSSTcorp CDW/DVD TS-H492A driver is not reading DVDs
my tsst corp cdw/dvd ts-h492a is not reading any dvd's how do i fix this problem without having to spend $29.99 for another program?
where can i download the drivers for this drive?
Nov 14, 2007 | Samsung TS-H492A/RSWN CD-RW/DVD-ROM...
Gateway GT5408 PC Desktop Logo
630 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
