Question about Mustek MP100 Portable DVD Player
My portable dvd player is not spinning. May be it fall down but everything else is working. any one please help?
Hi i have a slot portable dvd player everything works fine only its say disc error beacuse its not spinning. any one can help
    Sergeant:
    Champion:
  • 255 Answers
Have you tried other disc?
Posted on May 28, 2009
Try cleaning the lens or try to see if the motor is spining
Posted on Jun 07, 2012
My Sony DVD/VCR combo will play cds but not dvds. I took the top of the player off and I can see that the dvd spins but it won't play. It used to play everything very well but just stopped working...
Please clean laser lens with good quality cotton bud gently and check dvd disc playback, if still does not play, replace optical lens block.
Let me know model number of your Sony DVD-VCR combo to provide you optical laser block part number info.
Thanks.
Nov 15, 2009 | Zenith DVP615 Portable DVD Player
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Mintek portable dvd player
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 08, 2009 | Mintek MDP-1815 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Keeps saying loading but never shows picture
take your set to tech the lens need to be adjust or the strip is getting in the way.
Feb 19, 2007 | Sungale PD708 Portable DVD Player with...
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Mustek MP100 Portable DVD Player Logo
369 people viewed this question
Top Mustek Televison & Video Experts
Jonathon summesfield
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
