Question about Panasonic SC-HT730 System
No surround sound in tv or vcr mode
No surround sound
  • losey Oct 21, 2007
    urgent
  • chogumchonsa Oct 12, 2008
    I only have front speakers on TV Mode
For some reason this Panasonic unit does not offer surround sound in TV or VCR mode.  I guess their engineers decided it wasnt an important feature!!
Posted on Oct 22, 2007
2 Suggested Answers
bluenadas
  • 203 Answers
SOURCE: tv surround
It depends on what you currently have as equipment.
You'll have to have something that outputs in digital audio (coaxial or optical). Either your reciever (Cable/Satellite) or the TV. You'll just hook that up to the Surround Sound unit and then just turn on the Surround System when you want surround sound.
You'll have to connect the TV as you would normally with audio cables sicne you'll want stereo sound on the regualr channels.
Posted on Nov 22, 2007
I have rca DVD surround can I hook up so reg TV and DVD is surround sound both
you have to start with surround sound to get surround sound so no,but if you want sound out of the speakers on the surround sound from your tv,you can do that.
May 10, 2015 | RCA Televison & Video
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
What is the time delay switch for on a sa 5760 receiver
Hi,here is the basic info for your question..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Surround Sound System Settings ---- Correct Time Delay Setting in Multi-channel Audio
A correctly set surround sound system can yield dramatic improvements to your
home theater sound or multi-channel music listening experience. In particular,
a correctly set time delay setting between the different channels is essential
for a realistic and unified surround soundfield.
Luckily, most of today's surround processors make setting the time delays
between the rear and the fronts a matter of a few entries in the setup menu.
Yet having a proper understanding of the principles behind correct time delay
settings is essential for the best results.
In this guide, we explain the principles behind time delay settings in surround
sound and show you how to adjust your surround processor or AV receiver for the
best surround sound field.
Time Delay Setting in Multi-channel Surround Sound Systems
Correct home theater speaker placement and properly balanced sound levels
between the different channels in multi-channel audio, while crucial, are not
enough to sustain a unified soundfield in a surround sound setup. A correctly
set surround sound system requires that sound from all the different speakers
reach the listener at exactly the same instant.
This explains why all fronts, left, right and center channel speakers, should
be set at exactly the same distance from the listening position. At the same
time, in a typical home theater setup, the surround speakers are closer to the
viewer than the fronts.
To compensate for this distance discrepancy, surround sound playback systems
apply a split-second delay to the surround sound channels.
Jun 22, 2011 | Technics Audio Players & Recorders
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
How do u get surround sound out of all the speakers when watchen tv
Most of the time, you will only get surround sound out of all the speakers when the Soure (ie Cable, Satellite etc.) puts out surround sound. The receiver can only give what it gets (unless it has a simulated surround function, in which case it wouldn't be true surround sound). If you can check the info from the source, see if it shows you Dolby 5.1 or DTS as an option. If these aren't available, then you won't get surround sound. Hope this helps!
Mar 01, 2011 | Samsung HTC550 Theater System
No surround sound coming from tv. surround sound
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Dec 20, 2009 | Audiovox 150W DVD Home Theater System -...
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound output from Center and Surround speakers
the only time the center and surround speakers put out sound is when it has a surround sound source such as a dvd etc. and only certain sounds come from them as well.
May 23, 2009 | Kenwood VR615 Receiver
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Panasonic SC-HT730 System Logo
197 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
