Question about Tascam US-144 Sound Card
Tascam Us-144 Only plays back in left speaker
Only plays back in left speaker. If i hook my computers default soundcard back up it plays in both speakers.. It was working fine for past month or so, then i tryed to hook up a guitar through amp and suddenly this problem comes up. any ideas? I have the same problem. I have a Rode condenser mic plugged into one side of the interface, and I have the interface and Cubase set up exactly how they showed on the Tascam website, and I'm only getting sound out of the left speaker. Not only am I getting all my recordings out of the left speaker, but when I IMPORT stuff into my tracks that are set up for the US-122L, THEY only play in the left speaker as well! I've emailed tech support, they must be outsourced to Venus or something because I haven't heard back from them.
  • 1067 Answers
SOURCE: Cubase software does not recognize my TASCAM US-144
do u have usb 2.0 prts in back use not front of pc those 1.1 ports ok cheak drivers on all tell your master sound drivers defult to tascam see what happends
Posted on Jan 17, 2008
SOURCE: tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Posted on May 03, 2008
  • 3 Answers
SOURCE: No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Posted on Oct 19, 2008
SOURCE: Tascam Us-144 Only plays back in left speaker
If you have a condenser mic you need an adapter that you plug both into the right and left...
Posted on Apr 30, 2009
  • 63 Answers
SOURCE: tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Posted on Apr 11, 2010
My tascam us-144 only plays in left ear, and I do not have cubase, need fix!
Hello you can download a manual and other stuff here:
You need adobe reader to read the content.
Good luck
Dec 12, 2012 | Tascam US-144 Sound Card
I just switched computers to a "Satellite" by Toshiba. On my old computer (windows XP) my TASCAM us 144 worked perfectly on a free program called WavePad. My new laptop runs Windows 7 64bit. I...
It sounds like it maybe an asio problem or latencey issue. You need to increase the latencey in the control panel of your tascam soundcard and this should hopefully cure you .
Jan 07, 2011 | Tascam US-144 Sound Card
Tascam 144 sony acid pro 6 no sound from midi track
It sounds like you may be confused on what the MIDI part actually does. MIDI records your performance, not your sound. Then you assign and play back the recorded performance to either a virtual instrument (in which case you should here sound from your computer) or to a real physical MIDI capable instrument (in which case you would here the sound coming from that real instrument instead of the computer).
The ends of the MIDI cables themselves are identical, not IN or OUT.
Feb 01, 2009 | Tascam US-144 Sound Card
Jan 18, 2009 | Tascam US-144 Sound Card
Can't get a signal with my Tascam US-144
Make sure the Tascam is has updated drivers. The latest driver is Version 1.12. Something that helped me as well was to re-route my sound card to the Tascam. Meaning to have Windows, use the Tascam as the sound card for the computer.
This is the advice I followed from a forum it helped me alot!
I eventually disabled all other sound cards on my PC. In my case it was simply the integrated soundcard on my motherboard. I did this in the bios setting. I also uninstalled the drivers for it, just in case. I was having problems hearing anything in Cubase before I did this.
I set the US-144 as my default sound device in Windows (Control Panel>Sounds and Audio Devices>Audio)
I'm not sure what you are trying to record so I will give you a guitar example.
Guitar plugged directly into LINE/GUITAR IN R using the 1/4" jack with the switch above it in the GUITAR position. You can use the INPUT R dial to adjust the input volume for this channel. The SIG/OL light should turn green when you strum the guitar.
The US-144 is plugged into a USB 2.0 port on the PC.
Speakers are plugged into the LINE OUT jacks on the back of the US-144. The MON MIX dial will adjust what goes out through these jacks. If you move the dial all the way to the left, you will hear the input from the guitar directly from the US-144. If you move the dial all the way to the right, the signal goes through the US-144, into the PC via the USB connection, then back to the US-144 through the USB cable, and then out through the line out jacks. You may not hear anything when it is all the way to the right until you have Cubase open and configured properly. IMPORTANT NOTE: If you have MON MIX dial turned all the way to INPUT, you will not hear anything being output from your computer.
The LINE OUT dial adjusts the volume through the LINE OUT jacks. Make sure this isn't turned all the way down.
At this point, you should be able to turn the MON MIX dial all the way to INPUT and hear your guitar. It will probably only be coming out of the Right speaker, which is what it should be doing. Now turn the MON MIX dial back to somewhere in the middle so you can hear both the input from the guitar and your PC.
I downloaded and installed any updates that were available for Cubase LE 4 (I think all I needed was the 4.1.3 hotfix).
In Cubase goto Devices>Device Setup>VST Audio System and choose the US-122L /US-144 ASIO driver from the pull down menu. I'm not sure how important the "Relase Driver when Application is in Background" checkbox is, but mine is unchecked. If you click on the US-122L / US-144 section, you will see a button for the Control Panel. It will tell you what your driver and firmware are and what USB mode you are operationg in, etc. I didn't mess with any of these settings, but it is good to know how to get there. You should also see all your in's and outs. I have 2 analog in's and out's and 2 digital in's and out's. I am only using the analog in's and out's. Hit OK to close out this menu.
Now goto Devices>VST Connections and you should get a new window. There is an "Inputs" tab and an "Outputs" tab. Under Outputs, you should have a Bus for Stereo Out using the US-144 as your Audio Device and the US-144 Analog outs for the device ports. Make sure the "CLICK" colum is checked if you want to hear your Cubase metronome through your speakers. If you don't have a bus, add one and set it up as I have described.
Now goto the Inputs tab and add a mono input using the US-144 analog in R as the Device Port.
Now start a new project and add an Audio track using the Mono in and stereo output. Use the Edit Channel Setting button if you have to change your input and output.
Now with the MON MIX dial all the way to the right and with the Monitor button enabled on your audio track, you should be able to hear your guitar through Cubase.
Now if you turn on the Record Enable Button on your track and then press the Transport Record button, you should be able to record your guitar. Hit stop and then go to the beginning of the track and hit play. You should be able to hear what you just recorded. Don't forget that if the MON MIX dial is all the way to the left, you won't hear anything from your computer.
Well that is my Cubase LE / Tascam US-144 Getting started guide written by a newbie for newbies. May my pain and suffering alleviate some of yours. Good luck.
Dec 26, 2008 | Tascam US-144 Sound Card
Are you hearing the sounds from your speakers on your computer only?...accordianman
Feb 03, 2008 | Tascam US-144 Sound Card
Jan 15, 2008 | Tascam US-144 Sound Card
Wonder if you can help with this sync issue with the sound
There is a setting in Cuabse where you can select an ASIO driver, play around with this.
I assume you are using cubase
thanks for rating
Jan 09, 2008 | Tascam US-144 Sound Card
Tascam US-144 Sound Card Logo
381 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Chris Larocque
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
