Question about Epson R320 CD / DVD Printer
The color on my photo is blue on Epson printer R320
The color on my photo prints has suddenly turned much too blue and looks pretty bad. Is this the ink for some reason? I am having the same problem and nothing changes.  Cleaned and re-aligned the heads, changed all the inks.  Cleaned the inks myself, changed color profiles, printing profiles, any kind of setting possible. Why is it printing mostly blue?  And nothing will alter it?
  • 344 Answers
This is a common issue when printing using windows software, especially XP since SP2, my advice is always use the Epson software to print. Hope this helps
Posted on May 27, 2009
  • CHARLES ROBERTS Oct 05, 2011
    I have same problem changed every thing same result so I tried as you reccomend still no difference
My Epson R320 prints yellow over everything
One key diagnostic you need to perform is a nozzle check. This will tell you what has happened to the other ink colours as much as indicate if yellow is polluting other nozzles.
You can run a nozzle check from Printing Preferences > Maintenance.
Once it has printed you should (normally) see a sort of stepped grid pattern similar to this.
If you can scan or take a photo of the output and the post it as a follow up it'll then be possible to get a bit more of an idea of what could be happening.
Jun 30, 2013 | Epson Stylus R320 Digital Photo Inkjet...
MacBook Pro Epson Print Driver Dilemma
your problem is about profiles. The gutenprint is the only way to print from intel to r1800, but this driver don't use the same ICC profiles. You have to use one of three solutions below:
1 the best, you have a profile calibrating device, you make a profile of your couple ink-paper and you convert your document into this ICC profile.
2 you convert your picture into your software in one of the Epson generic profiles (hey probably still are on your computer) and you print whithout color managment
3 (awful) you anticipate the color distorsion and you tune your picture to be bad on the screen but pretty good on paper.
Feb 03, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Printer spooler not running
try this :
click start -> run -> type services.msc then hit OK
look for the spooler service and turn it on
Dec 14, 2007 | Epson Stylus Photo R200 InkJet Printer
When you run the nozzel check, do each of the colors print out right, or just the magenta ones?
Oct 28, 2007 | Epson Stylus Photo R320 InkJet Printer
New Canon Rebel xti photos won't print on my Epson Photo R320
Re-install the printer after downloading the latest driver from Epson. It is quite likely that the Canon software has over written the colour profile for the Epson.
Sep 16, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson R320 CD / DVD Printer Logo
416 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
