Question about Samsung HCN653W 65" Rear Projection Television
Samsung HCN653 Won't turn on, red timer light flashes.
I have a Samsung HCN653 65" Rear Projector. It does not turn on. The power button seems to be a little loose but working. When I attempt to power the tv up I get a red flashing timer light. Sometimes when i hit the power button I can hear it try to power up, but nothing happens including no picture or sound. Please give me some direction.
5 Suggested Answers
  • 308 Answers
SOURCE: Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Posted on Dec 20, 2006
SOURCE: samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
Posted on Jan 19, 2008
  • 310 Answers
SOURCE: won't turn on
Can u tell me model no and brand name so that i can help u sir..
Posted on Sep 03, 2008
  • 8457 Answers
SOURCE: When I turn my rear projection television on, the
Ur power board ic converter board it dead.
U know about a little about electronic the plug
go direct to the board order that board or repair man cost part labors about $575.
Posted on Aug 13, 2009
Green light flashing won't turn on
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Apr 08, 2014 | Mitsubishi WS-65611 65" Rear Projection...
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
XV-H37U projector. Red power light is on when
reset the lamp timer. it's usually hold menu button , down arrow, and enter, and press power. but it's an old projector and may be different.
Nov 29, 2009 | Sharp Office Equipment & Supplies
MITSUBISH WS 65807 GREEN LIGHT TURNS OFF PROBLEM
you could try checking your convergence board, i have a samsung that when powered on the red timer light flashed a few times and then went out , turns out it was my converge board, when i unhooked it the worked again colours were out of align ,but fixed board and all is well
mikeyfix
May 07, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi medallion 1080 tv
try unplugging your convergence board and see if it powers on my samsung had similar problem except red timer light,anywho i unplugged mine and it powered up
Apr 27, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Red timer light flashes but will not turn on green timer light flashes when plugged in. No buttons on remote or tv work. Tv will not turn on or off.
hay chap i have a front projector mad by the same company . u have probably owned this awile now and noticed its dimming a bit but still watchable . these sets are a pain cause even thought the bulb is good it will give u the red light of death . this means the computer in your tv is saying its time to change the bulb . mines doing the same . i know it sounds stupid and trust me it is but thats what it sounds like . what i have been planning to do to mine is pull the bulb out and put it back in to see if it resets the timer on ther computer for the bulb life . i could be wrong friend but thats what i would have to figure it to be . let me know if i was any help.
Aug 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
294 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
