You'll have to open the PC, locate the Bios battery. It looks like a small coin. Look closely for a 3 pin jumper close to the battery marked reset. Move the jumper from it's present position to the opposite position and wait about 5 minutes then restore the jumper to it's original position. Of course you need to do this without the power cord connected to the PC. Once you have accomplished this then reboot the PC, enter bios and you should be able to access all the bios settings.
There is a battery in the mother board ... take it out for a few mins and then put it back.... problem solved
click start control panel Open User Accounts in Control Panel. On the
Users tab, click the name of the user whose password you want to change, and
then click Reset Password. In New password and Confirm new password, type the
new password, and then click OK. Notes You can change passwords only for local
computer accounts, such as guest, administrator, or accounts you create for
your computer. You cannot change your network logon password in User Accounts.
To change your own password, press CTRL ALT DELETE and then click Change
Password
also
if you are not the computer administrator and have not assigned a bios password
during the boot up process you will see on the screen for a short amount of
time press a certain key to enter set up Press and hold that key during the
boot up process to enter BIOS scroll down to set user password or supervisor
password you can change or remove your password from there also
click start control panel user
accounts on the users tab,click the name of the computer administrator you must
have full control can change the password there
Also
i have used this software and no that it works although
you might have to get a computer with an internet connection to download and
burn it to a disc
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that
allows you to repair, restore, or diagnose almost any computer problem also has
a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to
boot from the disc
During
the boot process you will see on the screen to press a certain key to enter
setup Press and hold that key during the boot up process to enter BIOS the
scroll down to advanced bios features press enter change your first boot device
to cd press escape then press f10 to save to cmos to restart (note after you
have removed your password you will have change first boot back to your hard drive)
http://www.filebuzz.com/findsoftware/Free_Password_Remover/1.html
you fill find a few password removal programs pay and
freeware
Hope this helps
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password http://majorgeeks.com/Bios_d235.html http://majorgeeks.com/CmosPwd_d239.html hope this helps
also
When you boot up to the log in screen type in administrator as user to log in if you cant log in during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there
Save, delete, and restore your BIOS settings
or http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
hope this helps
To resolve this issue, create a BIOS administrator password and delete previous ProtectTools user logs by following this procedure:
Download and install the latest SSM utility (SP42536).
Softpaq Description
Information
Download
HP System Software ManagerVERSION: 2.10 Rev. A
SP42536 Instructions/Information
SP42536 File Download
Navigate to c:\Program Files\Hewlett Packard\SSM .
Access biosconfigutility.exe to reset the BIOS administrator password.
a. From a command prompt, navigate to the SSM folder.
b. Type biosconfigutility.exe to start the utility. A list of commands displays.
c. Type /newsetuppassword:"password" to create a new BIOS administrator password.
d. Close the command window.
Restart the notebook PC and press F10 at startup.
Log in using the new BIOS administrator password.
Choose User Management and delete any previous ProtectTools users.
Save the new settings and exit startup.
