Question about HP Computers & Internet
Bluish greenish screen
Seems monitor will be just fine for sometimes weeks and then all of a sudden turns bluish and greenish
    Problem Solver:
  • 14 Answers
Happened to my tv. Sign of tv or monitor going bad.
Posted on May 28, 2009
Cannot use the 5 push-bars on X7G-NagaV to reduce the pink (red in) the background. Do you have instructions for which button to push & the sequence? Thanks
Please check to make sure that the pins on both ends of the VGA cable are OK and seted properly on bothe ends.
There is no adjustment for color casting on the screen (redish, greenish, or bluish cast).
You may have problem in the monitor or the video card.
http://s807.photobucket.com/home/budm/allalbums
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
May 09, 2010 | Sceptre X7G-Naga 17" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Greenish screen
sometimes speaker magnets or any metallic device can cause this disturbance in this type of monitor. also, if you are using dvi, i would reset all video driver settings to default. this may correct this green tint you are seeing as well. reinstalling the monitor software could have a positive affect.
Feb 05, 2009 | Dell E196FP 19" LCD Monitor
Computer boots fine but the monitor is blank
if the monitor works fine on your laptop, the problem definitely is at the computer, possibly with the video card (if it is using one). it could have loose connection, or parts might have damages. it seems the problem is intermittent so electronic component of the video card could have parts partially damages or leaky components.
if your still using the motherboards built in video out put, try installing a new video card.
Oct 31, 2008 | Computers & Internet
Screen has bluish hue to it
Check monitor cable to back of pc if loose you can lose a primary colour. also if your pc has seperate video card can be loose reseat in slot.
Oct 02, 2008 | E-Machines eMachines Desktop PC
Color and brightness problem
Has it been dropped? At first it sounded like it may be have been an intermittent short if the CRT guns, but it's hard to say. Since it doesn't seem to be the cable, it sounds like this one needs component-level troubleshooting.
Jan 07, 2007 | LG Flatron F700B 17" CRT Monitor
Bluish screen -
is it a greenish blue?..... if so you have lost your red signal..... check your monitor connectors for bent or broken pins...... usually happens after swapping cables or monitors on a computer..... you could also have a bad cable or monitor..... is the monitor a CRT or a flat panel.... loss of one color is very common on CRT monitors, and could be a bad solder connection on the CRT driver board, or a bad video chip..... flat panel LCD monitors don't usually lose a color, although it is possible.... the most common failures on LCD flat panels is total power supply failure (no power at all) or display matrix driver failure (colored stripes across or down the screen), but a cable failure is also possible, like i said above, check the connectors for bent or broken pins..... there are 3 rows of pins...... at the widest side of the connector, there should be at least 3 pins next to each other on that row (sometimes there are 5), the middle row should at least have 3 consecutive pins as well (and again, there are sometimes 5) the last row (the smaller side of the connector) should have at least two (but sometimes all 5) pins in it. the first row and last row of pins should line up vertically, and the middle row is offset a half a space, so from top to bottom, the columns of pins make a zigzag...... if the connectors are alright, then your most likely problem is the monitor..... if another monitor works on the computer, it's the monitor..... if another monitor has the same problem on this computer, then it is the video card (or the motherboard's video output, which is fixable by installing a video card)
Jul 26, 2006 | MPC Computers Envision EN 5100e 15" Flat...
Bluish screen
Before spending money on a new video card you might not need. Check all your connections. I have a monitor built into a Radio station announcer's desk and it goes blue at switch on. All I did was reposition the input cable and problem solved. It was caused by a fractured wire or two in the output cable and moving it made them make contact again. It's worked for 4 years now, if it really dies then I'll have to pull it out and replace the whole cable. Check that all your inputs and outputs are firmly plugged in and any securing screws are finger tight. But remember the old tech's saying "If it's gonna go wrong it'll usually be in the first few weeks" BMW
May 26, 2006 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
