When attempting to rewind vhs tape, tv turns off and tape pops out unwound
After viewing vhs tape, upon attempting to rewind, the television turns itself off, and tape pops out without rewinding.     I clean the tape heads, and have tried different vhs tapes (Sony is my favorite), but get same results.
thanks
    Habit-Forming:
    New Friend:
  • 75 Answers
Lamp sensor in middle of tape carrier is blown.
Posted on Jan 01, 2018
unclejed
  • 26 Answers
SOURCE: Toshiba MV13P2
since it fast forwards, and rewinds, my first guess (that the take-up mechanism is worn, which also causes the machine to "eat tapes" after it stops) not likely..... the other common problem is misaligned sensors (especially if you recently had a tape jam in it, or found a foreign object, like a pen, or piece of candy in it...... another possibility is that if it's with a particular tape, you may have visible gaps in the coating on the tape, which would trigger the sensors, basically saying "STOP.... END OF TAPE..." there are other sensors and sensing conditions that could cause the same problem....... have the mechanism and electronics looked at by an expert.......
Posted on Aug 01, 2006
  • 41 Answers
SOURCE: symphonic sc1304, vcr problem
Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
Posted on Jul 22, 2007
Shuttle83
  • 1139 Answers
SOURCE: TV shuts off by itself
I think that this might be a power supply problem. The VCR might be loading down the supply and causing the shut down. If you are going to try to fix this yourself I would shuuest you get a schematic and multimeter, and an oscilloscope, here is why, The schematic will tell you what voltages are normal, The multimeter will allow you to measure those voltages, the oscilloscope will allow you to test for ripple voltage which might be present riding on your dc voltage level. If you do not have access to this equipment or do not know how to use this type of equipment, I would suggest that you take the unit to a shop.
Posted on Oct 03, 2007
SOURCE: VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Posted on Jun 30, 2008
  • 3422 Answers
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
Posted on Oct 09, 2008
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
Only easy way is to unplug tv / vcr from AC outlet and plug it again, now try to eject.
Oct 09, 2008 | Samsung CXJ1352 13 in. TV/VCR Combo
Panasonic PV-7400 VHS VCR seems to be stuck in Memory Rewind Off mode. I power on, it attempts to rewind (though there is no tape in there now) for about 20 seconds, then powers off. I've pulled
Most of these problems are caused by a faulty mode switch. If the mode switch has gone off of it's true position, then the electronics might well think it's in rewind mode even in the off position. Sometimes it's just the switch that is faulty, but sometimes damage to the mechanism has thrown off the switch.
Apr 14, 2013 | Televison & Video
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
VHS tape
is it a specific one particular tape? Or is it that all VHS  tapes that you put into the VCR or Rewinder do not rewind? Do clarify
Oct 24, 2007 | Optical Coating Model 108 VHS VCR
Televison & Video Logo
251 people viewed this question
Top Televison & Video Experts
