Question about Kenmore 44072 Front Load Washer
Kenmore front load washer #44072 drum banging noise
My 4 yr old front load washer is making a banging noise during the spin cycle. I didn't let it get to a fast spin. This was during the slow spin. The drum seems to have more movement than usual. Kenmores are notorious for this and their service is awful. Sears does not stand behind their products.
  • 89 Answers
2 possible issues with your washer.
1 or both the support shocks or springs have broken
the drum would look off center even when empty
or rear bearring has worn out.
this is a very common problem with the fridgidaire washer... (this kenmore is a frigidaire model)
problem is caused by very hard water (well water) or improper use of detergent. this machine uses a High efficency type detergent, marked by "HE" on the detergent container
Posted on May 27, 2009
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
It just recently started making banging noise during the spin cycle it is 6yrs old and i called sears but the warranty has expired and it cost $100 for a techican to come in for 10 min
Check you 4 springs are ok 2 top 2 bottom with struts...Next make sure concrete weights are not loose also the machine is level...if excessive play on inner drum then this says possible bearing problem....
Feb 02, 2011 | Kenmore 44072 Front Load Washer
Loud banging noise during spin cycle of my front loading kenmore
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Dec 23, 2009 | Kenmore Washing Machines
During the spin cycle the front load washer makes a loud noise. Sounds like a bearing going bad.
you got it,and the whole tub has to be replaced because it's all one piece-mike
Jun 30, 2009 | Kenmore 44072 Front Load Washer
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Mar 29, 2009 | Kenmore 44072 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore 44072 Front Load Washer Logo
762 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
