Question about HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue
No menu screen but there is sound. HP vs17x... Screen won't come on. Blue Power Light Flashes. Built-in speaker make a clicking noise. Worked fine yesterday, don't work today! HELP!
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
If i turn my computer off for whatever reason, when i try to turn it back on, the monitor remains black, the blue power light flashes and the monitor emits this horrible hissing sound. I can eventually get...
Try this, no guarantees but it may need to be reset. Make sure PC is turned off. Disconnect the monitor from the PC and unplug it from the wall. Hold in the Power button for at least sixty seconds, then replug it in PC and wall. If it is reset it should start normally. If not it needs further diagnosis.
Jun 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Monitor flashes blue light and takes a long time to come on
Disconnect monitor cable from back of the computer and see if u have a error msg on the screen > if u find a error msg like " NO VIDEO SIGNAL"> then ur monitor is fine or else ur monitor is BAD
Oct 20, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17X monitor blue power ligth blinking, nothing on screen
Sounds like a power surge fried the electrical connections inside.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Not working.
Did you install the software for the monitor? If you do not have the disc, You can download the driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=447382&lc=en&cc=us&dlc=en&submit.y=7&submit.x=8&lang=en&cc=us
If you have any further problems,let me know. Thank You for using Fix ya!
Aug 23, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
663 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
