Canon EOS Rebel G 35mm SLR Camera Logo
A
Anonymous Posted on Jan 14, 2014
Rewind button stuck - Canon EOS Rebel G 35mm SLR Camera
Ric Donato
Level 2:
Novelist:
  • Canon Expert 232 Answers
  • Posted on Nov 28, 2016
Ric Donato
Canon Expert
Level 2:
Novelist:
Answers
232
Questions
Helped
87629
Points
291
Is there film in the camera? If it is then in a dark closet or change bag open the camera remove the film then manually rewind the film into its cartridge. Once the film is in the cartridge now you can look at the inside of the camera in the light, you should be able to get the rewind to work.
1helpful
Film rewind button at the bottom of the camera stuck on the "in" position. Cannot get it to release.
Put the camera in a change bag open it then manually rewind the film. From there you may be able to free the button. If the button continues to be stuck here is something worth trying that I have seen others do with stuck buttons and aperture blades. To the button add a few drops of lighter fluid let it soak in. Sounds crazy yes, however sometimes that will dissolve gunk buildup freeing the button. That trick works wonders on stuck aperture blades; actually a common practice at repair shops.
May 27, 2015 • Photography
Tascam 238 recording deck won't stop rewinding.
This is a solenoid controlled deck. INITIALLY I'd say your rewind button is stuck in the pushed position. sometimes dirt, grease, smoke narrow the clearance between the buttons. THEN I'd say the relay that controls the solenoid is stuck in the engaged position. THIRDLY I say the solenoid ITSELF has some metal filings or dirt in IT, and it is jammed. Let me know
Film rewind button stuck
Try cocking the shutter with the camera back open, if that does not pop up the rewind button the camera may need service and lubrication.
Nikon f601 won't rewind
needs repairing at a qualified shop
The rewind button on my diana camera is stuck OUT - as well as that I can't rewind my film as the rewind lever is stuck - can you please help?
Take your camera to photo developer who has the dark room. They will open your camera in dark room and remove the film without any damage to it. Once film is out you can see whats actually the problem, it can be gear tooth misaligned or something.
Plug/wire is stuck partially out (4-5 inches)pressing on rewind button nothing happens....just stuck!
This usually means the cord got twisted over itself. Pull it completely out and give slight resistance on cord and rewind it again.
Rewind stuck on reverse
Hi Luce n Steve, To quote JC at Photo.Net: "sometimes the rewind function "gets stuck" if the camera thinks a previous rewind did not complete successfully. The solution is to reset it by forcing a rewind operation. Just press the two rewind buttons simultaneously: on the left side of the lens and just behind the shutter release. (They are marked and the manual explains how to force a rewind.) I did exactly this, and my next roll of film loaded without problems." Hope that help you folks.
Rewind button is stuck
It can definitely be fixed but let's try one thing before forking over few bucks to technician. Assuming it is a SLR camera, When you rewind, hold the rewind knob pushed in and try it. If you have a point and shoot, let me know which model. I'll be ready to assist when you respond either way.-James
My phone is a nokia n95 8gb. My problem is that it keeps rewinding music without me pressing any buttons?
Maybe the rewinding button is stuck, release it, i had the same problem but onlt the 7 button was stuck.
Jun 30, 2008 • Cell Phones
Top Canon Photography Experts
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Canon Photography Expert? Answer questions, earn points and help others
