Question about Kenmore Washing Machines
Breaker trips when unit is turnedon. Breaker works properly.
BRAKER TRIPS WHEN UNIT IS TURNED ON.All settings. Breaker has and does work properly.
  • 15,935 Answers
Replace the timer.
It is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Dometic Duo Therm RV AC makes clicking noise when turned off
The braker is getting weak and needs to be replaced the act should be cleaned as the coils get dirty and make the units work harder
Jul 19, 2014 | Dometic Heating & Cooling
Sparking in power box when we use the generator and trips the braker
When you say "power box" do you mean the main breaker box in your house? Is the generator hooked up to the breaker that you say trips when the generator is on? There is a short somewhere. First check the generator. Is it running OK. In other words if you plug something into the generator receptacle directly, does it work? If the generator itself works properly, then check the wiring from the generator to the circuit breaker. DO NOT use the generator until the problem solved = safety first.
Jun 12, 2014 | Cars & Trucks
I HAVE XB10 HVAC SYSTEM TRIPS BREAKER
could need a start assist for compressor or could be weak breaker
Dec 03, 2012 | Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Usually trips breaker but occasionally works fine....when hooked to higher amp breaker line works fine.
it could have a small leak to ground on it,,, thats why it trips the brakers,, on a higher braker the leek off also needs to be higher than 50milly amps to trip the braker,,, this unit uses 13 amps
Oct 31, 2009 | Faberware 12-55 Cup Coffee Urn
Breaker trips on roof top RV A/C
check your breaker is it hot to the touch?
check the wire tightness at the breaker?
remove the circuit breaker and inspect the terminals on the breaker and in the panel and the breaker itself for signs of overheating and discoloration due to the fact
check the connections at the unit itself
check that you have proper voltage to your unit
find the nameplate and look for FLA full load amp draw
is the breaker properly sized for the unit and is the wire size correct for the breaker?
(Check nameplate on unit)
buy a clamp on amp meter and see if it is under or over the nameplate rating when unit is running
take great care when you venture into electric,if you arent comfortable find someone who is.
you may have a weak breaker if all the above pass?
Replace it
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
