Question about JBL GTO 301.1 Car Audio Amplifier
JBL GTO 301.1ii protect mode
I have the JBL gto 301.1ii amp. i only have remote power and ground hooked up and its in protection mode never comes out i really need this amp workin due to buying ma audio subs yesterday any help will be great thank you in advance
  • Anonymous Mar 23, 2014
    Protection light and white jbl logo blinking
  • 655 Answers
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
Posted on May 27, 2009
Need a schematics for a jbl gto 751.1 ez car amp please
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Are you a technician? .A thumbs up would be greatly appreciated if this answer is helpful to you
Jan 04, 2015 | Car Audio & Video
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
I have a JBL GTO 7001, it switches in an out of protection mode. i pulled out the amp, an noticed that the positive wire from the speaker was pulled out. so i disconnected the power scorce an reconnected...
Make sure that your positives and negatives are lined up correctly. This happened to me during my latest install and the problem was I had one positive speaker wire plugged into a negative speaker terminal. This switches the amp on after a few seconds and then back to protect mode once it detects a faulty speaker wire. Hope this helps!
Oct 07, 2010 | JBL GTO7001 Car Amp
The amp goes in and out of protected mode
could be the sub wired incorrectly to the amp.i have had same problem and used same fix. everything has been workin fine ever since. check out this link an select the correct option for your set up an it will show you the sub to amp wiring
http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html
Mar 03, 2010 | JBL GTO 1201.1II Subwoofer Mono Amp - 800W...
Amp switches from power to protect over n over
Hello ryan_waslike,
There's a short or a ground somewhere on the system.
Start by checking your wiring and make sure there are no shorts and that there isn't any insulation rubbed off allowing a wire to come in contact with the vehicle metallic body or frame. Then disconnect the speaker and see if the amp will power up without going into protect. If it does, the problem is in the speaker or speaker wiring. Find and correct the problem and power everything back up.
Hope this helps.
Aug 02, 2009 | JBL GTO 301.1 Car Audio Amplifier
Amp goes into protect when turned up to higher volumes
check the ohm load on your speakers, you might have to low of an ohm and the amp is going into overcurrent protection mode, with the amp off use a multi meter at the speaker terminal with the speaker conected, should read 3 to 4 ohms, if it is lower then thats the issue, you also could have a short on one of the speaker wires, look for am=ny wire pinched in the door jamb or on the speakers, sometimes the terminals are close to metal in the door and you wont notice it. give it a try.
Jun 30, 2009 | JBL GTO Series RLC Amplifier Accessory -...
Amp is putting itself in protection mode.
I would check to see if you have a secure ground and check all of your connections for shorts.
May 09, 2009 | JBL GTO Series GTO1004D Subwoofer -...
Jbl stereo does not have power
You need to confirm that you have B+ and remote voltage at the amplifier.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 23, 2007 | JBL GTO 301.1 Car Audio Amplifier
No audio-amp protect light come on then went
You need to check the DC voltage across the B+ and ground terminals. You also need to check the DC voltage across the remote and ground terminals. If the voltage is less than 11 volts, you need to check the B+ supply and remote wiring for breaks or open fuses. You should also check the ground connection to confirm that it's not loose.
If the voltage is OK, the output transistors are likely shorted.
Oct 21, 2007 | JBL GTO75.2 Car Audio Amplifier
JBL GTO 301.1 Car Audio Amplifier Logo
387 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
