Question about Canon PIXMA iP8500 InkJet Photo Printer
Ink printer problem Canon PIXMA ip5800
Printer tanks are full and set properly.  Settings are at default.  Yet my printer for some reason now only prints out in blue ink instead of the black ink for text.  How do I reset it to print text in black?
SOURCE: pixma 500 - Ink Tank 'Not Recognized"
carefully remove the tanks from the print head cartridge. use a q-tip lightly soaked in isopropyl alcohol, or use a q-tip paired with an alcohol prep pad from a first aid kit.
gently rub the rubber seating areas for each tank, removing the dried ink from the rubber seat. swab the soaked q-tip, or use the q-tip to gently press the alcohol prep pad into the rubber stopper. use a different spot on the q-tip or pad for each one.
check the print head for ink stains on the black plastic, clean those as well.
Use canned air to dry the stoppers, replace the tanks, and check status. Print a test page and check results.
If you do not print many items, you can avoid the situation by printing a test page every once in a while to keep the contacts clear. Also, run the program to clean the print heads occasionally, and always turn the printer power off at the printer (that seats the tanks down on the stopper, helping to prevent the contact getting plugged by dry ink.
Posted on Apr 07, 2008
SOURCE: waste ink tank full error 5b00
Check out:
Posted on May 01, 2008
SOURCE: Pixma IP4500 Ink Tank Reset
When you replace your inks with genuine ones, your printer will automatically recognise these and reset your ink levels.
Posted on May 14, 2008
  • 787 Answers
SOURCE: Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Nov 04, 2009
  • 4041 Answers
SOURCE: I have purchased a
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
  • 10515 Answers
SOURCE: My Canon Pixma MP780 has
The reset procedure for the same is explained below :-
The absorber is a small sponge like pad inside the machine underneath the ink cartridge cradle. It sits underneath the cradle when the cradle is all the way to the right inside the machine. To fix this problem that pad needs to be replaced. Some machines will have a tank instead of the sponge. It is located in the same place. To fix that you would sinply need to remove it and then empty out the tank.There is no step by step guide to do this you would need to dissasemble the entire machine if it is a tank and not a sponge. If this is the first time it has ever occurred you can simply reset the error as there are normally 2 tanks. To reset it follow these steps.
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
2) Press the > key (also labeled +) six times.
3) Press OK.
4) Press the > key (also labeled +) four times.
5) Press OK.
XX (where XX is how full the waste ink tank is as an integer percentage)
6) Change the XX to 0 by entering 0.
7) Press OK.
The display will momentarily say:
and then will quickly change to:
8) Press the Stop/Reset button
If that doesn't resolve the problem, you need to get the printer serviced for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 16, 2011
0 characters
1 Points
My canon pixma 190 printer is not working
In printer utility settings, you have to modify the ink cartridge settings and specify that printer should use only black ink cartridge. Click apply. Then press "stop\reset" button for 5-7 sec. and then release
Then it will work!
May 01, 2010 | Canon PIXMA MP190 All-In-One InkJet...
The printer display shows the waste ink tank absorber is almost full.
After replacement:
1. Reset the waste ink counter.
Adjustment / Settings,
Waste ink counter setting]
- EEPROM information
Oct 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My refilled canon ip1600 ink jets are reading as empty
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Jun 09, 2009 | Canon PIXMA iP1600 Printer
Ink tank error message Canon iP3500
Canon ink tanks contain a chip allowing the printer to identify genuine ink tanks. You need to buy reasonable quality replacement ink tanks i.e. from (Google) 'Inkjets & Toners'
May 01, 2009 | Canon PIXMA iP3500 Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Confirm that the ink tanks are installed properly When replacing the ink tanks, confirm that the new ink tanks are installed properly. If the ink tanks are not locked into place, paper may not be fed properly, or ink may not be supplied to the print head.
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Jan 09, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
The 8BK is for printing photo's and high detail, it is usually only selected when you select to print high res / photo.
Nov 12, 2007 | Canon PIXMA MP810 All-In-One InkJet...
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
248 people viewed this question
Top Canon Printers & Copiers Experts
old marine
old marine
Are you a Canon Printer and Copier Expert? Answer questions, earn points and help others
