Question about HP Pavilion dv1000 Notebook
Trouble shooting start
When i put on the on/off button my laptop startsgiving a long constant beep with hp invent screen. it doesnt help if i do any thing or press any key
    President:
  • HP Master
  • 1,996 Answers
Here's a link to the HP online support site, where you can get detailed instructions on how to proceed to troubleshoot your startup error. The beep you hear is called a bios beep code or error code and is used to help diagnose the problem. If you look up the beep codes for your bios you'll find the meaning of that long beep. link from here
or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 27, 2009
    Sergeant:
  • 239 Answers
One long beep is a memory problem...might b ram is disloged from the position or is damaged..
My HP laptop starts with a white screen then fuzzes sometimes in between
Try to remove your LCD monitor check all connector must be connected properly, sometimes this happen if connector got lost contact.
If problem persist contact advance knowledge in trouble shooting Laptop monitor. This problem occurred when the bulb of LCD got Trouble.
Jan 14, 2013 | HP Computers & Internet
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
All I get is the hp invent black screen. computer
Try flipping it over, unscrewing the back panels and pop them off. Take out 1 stick of memory if there is 2, or take all memory out. Then try to turn it on. It will either do nothing but turn on and beep, or it will turn on but show nothing on the screen. Then shut it off and put the memory back in. Sometimes this kind of reset gets past that bios screen. Otherwise your memory may be bad. The other culprit can be the battery. Try removing the battery and starting it with it plugged into the wall. Let me know if this fixes your issue.
Apr 30, 2010 | HP Compaq nc6320 Notebook
Frozen computer
Try booting into safe mode and disable some startup items in the system configuration utility window. Another solution is to insert the OS disc and boot to the recovery console and type in fixboot c:
Apr 24, 2010 | HP Pavilion dv6000z Notebook
Beep on starting the laptop
Try to take memory out and put it back in to make sure they are seated in the slots properly and no loose.
May 27, 2009 | HP Pavilion dv1000 Notebook
My computer screen is stuck on hp logo nothing including key is responding my computer is stuck on hp invent screen.... it wont go past that, doesnt respond to f8 or esc. HELP
Sounds like a faulty hard drive that is locking up the system. Take out the hard drive completely and turn on the computer and see if it goes past the HP screen. If it does then the hard drive is bad. If it still locks up on you then reseat the memory one stick at a time in one slot at a time. If this doesnt work then you might be having motherboard issues.
Try these things and let me know what happens and I'll help you further.
Ben
May 18, 2009 | HP Pavilion dv2000t Notebook
Laptop Problem
If you are still in warranty, or even not, HP support is very helpful, moreso than most. If you have no computer access, call:
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products
Mar 01, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion dv1000 Notebook Logo
295 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
