Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Error code f7 on Kenmore wall oven 911.41165791
Unit just started beeping displaying error code F7! No idea what to do. I have a kenmore wall oven and for some odd reason it's not unlocking after the initiation of the self cleaning...the light is blinking but the only button i can use is the light button...how do i reset and get it back to work?
    Scholar:
  • 30 Answers
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Posted on Nov 08, 2009
  • Doug P Nov 08, 2009
    Problem Solver:
  • 7 Answers
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Posted on Aug 11, 2009
My Kenmore wall oven has a code F7 and is constantly beeping. What does this indicate?
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | Kenmore Ovens
Alarm comes on and display shows f7 code
Kevin
Apr 11, 2011 | Kenmore 47702 / 47704 / 47709 Electric...
''F7'' Error Code
HI. This is the result of a failed function key. This is an integrated part of the main control board. Unfortunately, this is not repairable, and the main control board will need to be replaced, asap.
Dec 20, 2009 | Kenmore Ovens
Try this first!
The control panel has a flat ribbon cable that plugs into the relay module. The ribbon is actually two ribbons pressed together. The plastic insulation has a defect, and the leads between the two ribbons cross. You can seperate them easily by lifting them apart. Place a piece of paper between them to act as an insulator. This should solve your problem. If that does not work, repalce the defective parts yourself. You can do it for about 30% of what a repair company would charge. it's either got to be 1. Control panel 2. Relay panel. Good luck!!!
Apr 07, 2009 | Kenmore Ovens
The F7 error code indicates that one or more potentiometers (burner switches) are not connected properly or that you have one or more failed potentiometers.
The specific details of this failure code are provided in the second image below.
This is an excerpt from the technical information for this range.
Normally, a service technician would be needed to conduct the troubleshooting and diagnosis for this type of failure.
If you are completely confident in your technical ability to safely unplug the range and access these potentiometers (54 in the third image example) you may be able to check for loose or broken wires that could be causing this code.
If no loose wires are found, then you will likely need to have a technician find and replace a failed potentiometer.
IMAGE1: http://media.fotki.com/1_p,wfdddkwdfrwkdtqxgtqsskgwtqkq,vi/gfwdtqtbrxgdkgqwqtb/1/1303472/5961857/image11662img-or.gif
IMAGE2: http://media.fotki.com/1_p,wfdddbrbbbbgfttxgtqsskgwtqkq,vi/gsfkbbsqqxgdtwdgbsg/1/1303472/5961857/image11663img-or.gif
IMAGE3: http://media.fotki.com/1_p,wfddfqsqwsbqtrwxgtqsskgwtqkq,vi/gtfggdrdwxgftrgbbtf/1/1303472/5961857/image11664img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 03, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore electric built-in oven control panel beeping
Try this first!
Aug 08, 2008 | Kenmore 42161 / 42169 Electric Single Oven
My oven wont quit beeping!
It depends on the actual model number (that you didn't supply), but most Kenmore F7 errors indicate a bad keypad or bad control panel. If you unplug the ribbon cable from the keypad to the panel then plug the oven back in and it starts beeping again, it's a bad control panel, if it doesn't beep anymore, it's a bad keypad.
Please unplug the oven power with working on it.
Geno
Aug 02, 2008 | Ovens
Kenmore Elect Built-IN Oven Model 790
You don't say what specific F code error. If it is an F7, go to the following link for my solution.
http://www.fixya.com./howto/h155060-dreaded_f7_error
I have shared my fix with over 1570 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Feb 23, 2008 | Ovens
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
981 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
