Question about Sanyo DS31590 31" TV
Buttons for power and channel don't work. Cable box remote won't work either.Can button assembly be replaced?
  • 50 Answers
I don't show buttons available anymore, have to check with sanyo direct.
Posted on Nov 20, 2007
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
Tv freezes when you change channels
Since it is unlikely to be the remote clarify a few things:
works ok with manual buttons or not?
Using buttons on the set or a box?
Cable box, sat box or and receiver in line?
Dec 10, 2012 | Televison & Video
My westing hous hdtv is stuck on channel 35-3 and will not switch to another channel, the remote doesn't work and neither do the buttons on the side of the tv, the power button works but won't
Try to unplug power from set for a while and plug back to reboot--immediately delete that channel from the set's memory as it may contain signal that is causing this.
Also look to see if the set has a feature to lock out the buttons and or the remote control---a few do.
Most likely something in the signal for that set caused the set to lock up.
Sep 02, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Guide button won't work on my remote
Either have those buttons checked on another unit or have the remote tested (some digital cameras will react with remote pointed at them)
You need to determine if problem is in remote or the unit.
Mar 25, 2012 | Sony Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
I have a visco TV and I cannot get it off of channel 1. The remote does not work so I bought a universal remote but it still won't work. I tried to codes for NEC and Polariod as suggested by others,...
There should be channel buttons on the TV itself, try using those. Also, you may want to try changing the input from the Cable Box.
I am curious as to why the remotes don't work. Also, how did it get onto channel one. Did you get the TV used?
Here is a link to the AV Science Forum. It seems other people have challenges with this TV as well.
http://www.avsforum.com/avs-vb/showthread.php?t=745952
May 19, 2011 | Televison & Video
I purchased a 32 inch flat screen coby tv on 11/2010. I am trying to advance the channels with the right up and down channel button on the remote, but it only goes to favorites. I only want to advance...
Are you using the cable box remote on the cable box or the coby remote on the cable box? or are you using the cable box remote on the TV or the coby remote on the TV? Try using the coby remote on the TV without the cable box connected first to see if the remote even works on the TV, replace the batteries and retry. then try the cable box remote on the TV to see if you have it set up correctly for that TV. Sometimes when you reprogram a remote to work other devices the buttons won't always end up working the commands that are labled on the remote, also there is more than 1 code that may work better than other codes or may match up with the labeled keys more closely. Low batteries will also make a remote act strangely.make sure the batteries also make good contact on the pins or metal pieces inside the remote. I guess I need more info on which remotes are being used for what purpose before I could give a more certain answer.
Dec 26, 2010 | LG Televison & Video
Synergy V remote - TV power on to last channel viewed - what's the code??
Actually, there is a setting in the cable box for this. You hit the settings button on the remote TWICE, then scroll down to Viewer:Power On. Click on what channel (or last channel) you want it to go to when you power on. Hope this helps. I have the 8300 HDC DVR.
Oct 07, 2008 | Televison & Video
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sanyo DS31590 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
