SOURCE: no heat in my 1999 ford taurus
It will be your water pump, the impellers will be corroded off, just like mine were.
SOURCE: The heater only blows luke warm air. Just replaced
Hello...
One of 3 things could cause this, that I know. The thermostat has been installed backwards. The water pump broke soon after install. Due to it being a rebuilt one. And a small clog in the heater core. All of these things are easy to fix.
Good Luck...
SOURCE: car warms up just fine but the heater blows cold air
both hoses is hot signifies thatcoolant circulation is just fine check the blend door actuator it might be stuck.pan the heater temp controller from hot to cold do you feel any change in temp of the air from the blower?if you dont feel any change check the blend door actuator
