Question about Olympus DS-40 Digital Voice Recorder
Olympus DSS Player Pro Woes!
Trouble is with DSS Player Pro Software - a companion software product, offered by Olympus for higher end digital voice recorders. We are running version 4,8, 4.9, 4.10 of the software. Each transcriptionist runs the DSS Player Pro application from a local installation. All of the 'Folders', which contain that digital voice recorder files, which they need to transcribe into a MS Word Document, reside on a file server. On occassion (too often), they can not play and listen to a recorded voice file. All Files are in the .DSS format - a rather obscure format developed by Philips and Olympus.  It supports ver high compression and sound quality.  Thus, most likely the reason used on the voice recorders that we use - the DSS-4000 model. When the transcriptionist enters the 'transcription module' they see a list of audio files.  Normally, the double click the file, it begins to play, and they type the digitally recorded voice file into a word processing document. On occassion, double clicking the file results in a message indicating that the file is being typed. I know this not to be true - typing is not yet started, let alone complete. I cannot change the status of the file by using the Tools menu, found within the DSS player pro application.  If I attempt to 'Change status', it results in the same message about the 'file being typed'. The details properties of the file indicate transcribe status as 'Transcribing'. The Author id is listed as 'DS4000' ??????? Please note, these file details are only available by exploring the file properties from within the DSS Player Pro application.  If the file properties are evaluated from the network server, there is no metadata field (at least that is visibile) which indicates a 'transcribing status', etc. Obviously, these files have been corrupted in some manner and the 'transcrining status is incorrect.   As an adminitrator of over 100 DSS-4000 devices, how can I correct this error.  I need to be able to transcribe these files that mistakenly are indicating that they are being typed - when they are not. I have many of them.   Any help is greatly appreciated.  I have many files in this state and do not know how to fix the error.  The 'change status" function is not working.   If we could figure out how to 'unlock' the file, or change the 'transcription status' I think we would be in good shape.  NOTE:: when I speak of unlocking the file, I am not speaking of removing a server level lock on the file.  I believe this is an application level, integrity checking mechanism, which has a bug, perhaps. Thank you very much.   Are there any utilitiy programs, patches, etc. that can fix this?
    Problem Solver:
  • 9 Answers
There is a small utility called dssclean, which can fix these files for you. Check with your Olympus Pro dealer, as they should be able to provide that for you.
Files usually get this way when a computer or the Transcription Module crashed while a file is open. The system doesn't get a chance to close the file and it remains in "typing mode."
The other, more readily available work around, is to select the file in the Transcription Module, then go to File > Convert File and convert it to a WAV file (it actually only makes a copy of the file). You can then transcribe the WAV file and delete the locked file.
Posted on Dec 30, 2008
  • 363 Answers
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
Posted on Oct 21, 2007
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
DSS player won't download to PC
I know you will need the serial # to install, if you don't have one you can get this software version it say that it is for the Olympus DS-5000 digital recorder but also it is compatible with the previous version Olympus DS-4000 digital recorder at http://www.tvps.com/Products/Olympus-AS-5001-DSS-Player-Pro-Dictation-Version-5---New__OL-AS-5001.aspx
Apr 03, 2014 | Olympus DS-4000 Digital Voice Recorder
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
My ds3000 dictation machine wont work with vista
The DS-3000 and the software is was shipped will not operate with Windows Vista. The software i suspect you have will DSS Player Pro Release 2 or 3. If you obtain a copy of DSS Player Pro Release 4 you will be able to use the DS-3000 on Windows Vista 32 bit or 64 bit without problem.
Jul 12, 2009 | Olympus DS-3000 Digital Voice Recorder
Intermittent ds4000 detection
The DS-4000 digital voice recorder is a product that is sold exclusively through authorized retailers.
Since this product is designed for professionals and is somewhat complex, the retailer will provide you with personalized sales and support please refer to your dealer for assistance.
Jun 02, 2009 | Olympus DS-4000 Digital Voice Recorder
I am unable to instal from CD the Olympuss DSS player pro version 4.9 on my second laptop - it just freezes - i need this to transcribe my work HELP
The DSS Player PRO software is a product that is sold exclusively through authorized retailers.
Since this product is designed for professionals and is somewhat complex, your retailer will provide you with personalized sales and support you may want to refer to your dealer for assistance.
Apr 07, 2009 | Olympus DS-40 Digital Voice Recorder
I have the Olympus DS 71 which records in WAV. Is
The Olympus DS-71 has two recording format WMA & PCM WAV. The Software that comes with the recorder is Olympus DSS Player version 7 , you have to upgrade your software from Version 7 to Standard (free) after you upgrade to Standard version you can convert to DSS
go here for the update :
http://www.olympusamerica.com/cpg_section/software_results.asp?id=1219&os=w
Now the link show olympus AS-2300 don't worry about it, just download the DSS Player V7 Upgrade to Standard
Hope this help .
Apr 04, 2009 | Olympus DS-2 Digital Voice Recorder
Olympus DS-5000 pro software issue
No, there is no way to change the record format to dss classic. However, with the pro software, you can set it to automatically convert to dss upon download.
Dec 22, 2008 | Olympus DS-2400
DS2 to DSS format
Dss Player Pro release 5 has the option to automatically convert to dss or wav upon download.
Dec 20, 2008 | Olympus DS-2 Digital Voice Recorder
Audio converter for dss audio files
You can convert DSS file into wav format with DSS Player 2000 or the latest version. it can only convert it into wav format. after convert into wav format then u can use any other converter to change it into any other audio format. u can use total video converter or Sonic record now multilanguage software.....
best of luck.....
Feb 08, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus DS-40 Digital Voice Recorder Logo
2,901 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
