Question about Breville Die Cast 800ESXL Espresso Machine
Worn out rubber seal for breville coffee machine cm5
The plastic concave washer for the steam wand seems to be worn and is leaking - looking for a replacement - not apparent on the Breville site. thanks, John McHugh I have a breville cm5 coffee machine & am told by breville cust services that the part(rubber seal about 55m diameter) is no longer available.How maddening that my machine which has had light use is now unrepairable!!! Unless there is an alternative or universal seal I could use that I do not know about Anyone help?? thanks v much Helen
  • 4 Answers
SOURCE: breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Posted on Sep 26, 2008
  • 18 Answers
SOURCE: Can't get tight fit between basket & steam ring
the proper replacement steam ring has an up-side & down side. the brew-head plate must be installed with the grooved side facing up; the steam ring has a groove in one side that fits over the top up the brew-head plate...does this solve the problem? if not, you may have the wrong steam ring/the brewhead plate may be installed incorrectly...oh, nov of 08...i seriously hope you've figured this out already. if not, you don't happen to still have machine in your possession, do you? if so, i'll buy it for $5.
Posted on Jan 11, 2009
  • 7 Answers
SOURCE: No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Posted on Mar 18, 2009
EsWorld
  • 1618 Answers
SOURCE: Breville 800ESXL backwash????
Posted on Jun 20, 2009
EsWorld
  • 1618 Answers
SOURCE: My breville espresso machine is leaking at the top
The o-ring /gasket in there might be worn out.
Posted on Oct 07, 2009
My brevile cafe roma coffee machine wont operate the steam through the spout to froff up my milk.
hi there, it sounds like the steam wand is blocked up...see page 11 of the following PDF that is for your machine. also see the cleaning section of that same PDF. Notice the "decalcifying" section. http://www.brevilleusa.com/media/mediaappearance/4553/ESP8SXL_IB_C11.pdf
Hope this helps you!
Jun 11, 2012 | Breville CM5 Espresso Machine & Coffee...
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
May 20, 2011 | Saeco Royal Professional Espresso Machine
Wanting basic operating instructions for CM5 espresso machine breville
there is no water coming through my coffee machine
it is a visa versa
May 02, 2010 | Breville CM5 Espresso Machine & Coffee...
Low pressure on milk frother on breville coffee machine
First,I'm NOT a Breville tech, but this is a very common problem with steam boilers. Your valve seal(s) are worn and needs replacement. Any leaking water or steaming from various places other than the steam tip is causing your tank to lose pressure. The heater needs to stay on longer just to keep everything up to pressure and properly heated. You probably noticed that your shots may not have the creme or very thin and watery. Milk steaming takes a long time or not enough steam to complete a froth, especially on a Latte. Your machine needs servicing. Contact your vendor or MFR for service.
** loose steam wands will fall off and be re-assembled without the ball seal or washer. Look around the machine for a round disk made of hard rubber or nylon plastic. Take apart the wand and reassemble with the washer or get a new washer and tighten,.
** other places were you can loose steam pressure is the Anti-siphon valve, Safety valve, and various pipe fittings to the steam boiler. Look for steaming plumes from unexpected areas of the machine.
** Scale that has built up to the point of causing valve problems are usually too much for DE-scaling to work properly. Usually done as a preventive maintenance rather an alternate to repair. Like a blood clot, if you remove it while still in an active system. Where does this clog end up? This debris needs to be physically removed from the pipes, valves, and/or tank. Heavy scaling is a sign of an old machine that will need a lot of servicing to bring it up to MFR specifications.
** Final; The steam wand(s) are the most used (and abused) parts of the machine. Constant cleaning is a required task that needs very diligent baristas to keep it fully functional. I've found that best operators use the following method to keep the steam wand in top condition; Remove milk froth pitcher completely from wand, Send a short blast of steam to clear milk residue from tip. Take a damp towel to grab wand an pull downward to wipe off any remaining milk residue. Leave the wand in a pitcher of cool water to soak during long break periods to help break up any dried milk. Let soak over nite when not in use. Have your operators notify you of any 'loosey-goosey" wands. Tighten them properly but make sure all the parts and washers are there. Check your manual or just ask your technician to show you the next time.
*Have a safe New year! Aloha! ukeboy57
Dec 24, 2017 | Breville Coffee Makers & Espresso Machines
The wand is leaking water
If the knob is fully closed and it is still leaking it's more likely that you have a valve or scale problem.  Either the seals in the shutoff valve are worn, or there is scale buildup in the valve which is preventing it from sealing properly.  First thing I would try is running descaler through your machine several times and seeing if that improves the valve seal.  Obviously if you are having a problem with the steam wand, make sure to run the descaler through the wand and not just the spoon !  If you've never descaled your machine and have had it for a while, you might want to run descaler through 6 or more times, letting the descaler liquid sit in the system between flushes to really get at the scale.  If it does not improve with descaling, then you should bring your machine to an appliance/coffee machine repair shop for them to look at the valve.
Mar 15, 2009 | Starbucks Barista Utopia
Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Breville espresso machine 800 ES
I have the same problem. It appears to be caused by a worn steam wand gasket that's inside the steam wand assembly which can be unscrewed from the Breville machine. This was confirmed by the folks at Breville. They referred me to www.thegourmetdepotco.com. That website does not sell the steam wand gasket separately. They sell "Frother Assembly MOdel #800ESXL-250" for $14.95. With tax ($1.42) and shipping via USPS ($5.65), the total is $22.02. A very high price for the failure of a simple plastic washer, but it beats buying a new machine!
Greg
Feb 24, 2008 | Breville Die Cast 800ESXL Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
406 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
