Question about Tvone TV-207 Television
TV all buttons are blocked and i don t have remote
I can t find back the remote and manual and due to a bad manipulation my tv buttons not working showing message 3amok please suggest me to open this lock i don t have remote. G-hanz ctf 72 2505/J 21" model tv srinivas.bsrinu@gmail.com 09866301056
Remote sensor on tv not responding I,have to turn on tv manually. change input manually,tv reception is ok. Volume cannot be controlled,it will lock in at full volume or drift back & forth,mostley...
Have you checked your remote to see if its working? If you have a digital camera or camera phone, point the remote at the lense and see if it shows up on camera screen. If it is working then the IR sensor on the tv could be bad.
Jul 17, 2012 | Sylvania LC420SS8 LCD TV
Cable remote AND vizio tv remote will not turn on the tv
We will presume you do not have two bad remotes---the fact you can operate the set manually with the buttons there suggests a problem with the remote receiver====there is a tiny infrared receiver in the front of the set that receives the signals from the remote and sends them inside the set where the correct action is taken.
Make sure if you see it (usually small black area on frame of set) it is not blocked or dirty.
Failing that you may have a bad receiver for the remote---shop repair.
Mar 15, 2012 | Vizio L32 32 in. LCD HDTV
I lost my remoe and manuel.I went to walmarts and bought a universal remote taht say its compatable with Broksonic..I will not work..want turn tv on or off? any sugestions?
U should turn on the tv ON manually by the tv power button to get the tv ON and used all the codes that was provided by the universal remote user manual for the ur tv brand Broksonic.U must follow the directions carefully and enter each codes correctly,the correct universal codes for tv is enter,ur tv will able to work by the tv universal remote power button will able to turn the tv off/on of the tv set.If none of the tv universal codes that was provided by the universal remote user manaul for ur tv brand Broksonic don't work.Just return the thing to Walmart and get ur money back.Try website like Remotes.com to buy the tv original remote,than 100% will work for ur tv set.
Aug 17, 2011 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
Light in on but the TV won't turn on
Try the following steps below:
- replace the battery of the remote control and then turn on the TV.
- try using another remote control of the same model (If there's another one like it)
- press the channel up/down button to manually turn on the TV or any button to activate it.
- try plugging it to a 110 volt transformer. (if your area uses a 220V power supply) Most TV's today are using autovolt power supply. (check the back to see if it says " 110-220v")
If you've tried them all, the power supply inside the TV is defective. Usually the Power Regulator I.C. is defective. It maybe also be due to a bad diode or transistor within the power block. Needless to say, you'd need to bring the unit to a service technician to fix it. And do not attempt to open the back and try to fix it yourself if you don't even know what a diode is.
And it is definitely not a busted fuse.
Jan 20, 2011 | Samsung LN32A330 32 in. LCD TV
Child lock on, TV off, No remote or manual=cannot turn TV back on
i found out on line in the owners manual that if u still have a remote control that came with the tv, u press the tv/av button and enter button at the same time to disable the child lock. New problem: u can't do it with a universal remote, even if its programmed to a magnavox tv. I called the 800 # to buy a remote control and the rep told me that it cost $50, not including the shipping and handling. so my husband put the tv in the car, brought an extension cord and took it to a local tv repairman who was kind enough to use his remote to remove the child lock for us. finally someone who is helpful for free. thanks to all the nice people out there!
Jun 16, 2009 | Philips Magnavox 27MS343S 27" TV
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Televison & Video Logo
61 people viewed this question
Top Tvone Televison & Video Experts
romy sibug
romy sibug
Computer Repairing
Computer Repairing
Falling star
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
